Old 01-15-2004, 05:28 AM   #16
Jase
twisted beyond reason
Jase's Avatar
I don't think a e30 could handle that much Hp. I figure it would buckle. I have seen those ones in europe with 400 hp but I am suresomething was done to the frame to stablize it
Old 01-15-2004, 05:30 AM   #17
Miguel
...Delt Smash
Miguel's Avatar
You think? 1995 E34 M5's had 335hp stock.... do you really think you'd need to reinforce the frame for an extra 65 Hp?
When you say reinforce, are you talking roll cage?
Old 01-15-2004, 05:31 AM   #18
Miguel
...Delt Smash
Miguel's Avatar
Alpina B10 from '89-'94 with the 3.5l bi turbo 6 had 354hp / 360bhp and Dinan 535i from '88-'92 with the M30 6 - 3.7l engine had 450hp / 457bhp stock with no reinforced frame.
Old 01-15-2004, 05:35 AM   #19
Jase
Jase's Avatar
I may stand corrected!. I was worried since I replaced my floors and the car was 20Years old it could not handle it.
Old 01-15-2004, 05:38 AM   #20
Miguel
...Delt Smash
Miguel's Avatar
But when you say REINFORCED FAME, what do you mean? how is a frame reinforced? Are you talking about installing some crazy 8 point cage?
Old 01-15-2004, 05:42 AM   #21
Jase
Jase's Avatar
More or less installing a secondary frame along side the original including connecting the sub frame together. Since the car is a unibody similar to a camaro the frame once connected is much stronger.
Old 01-15-2004, 05:47 AM   #22
Miguel
...Delt Smash
Miguel's Avatar
Im sure that would be a great thing to do, but I personally have never heard of a BMW with too much HP bending a frame... is that possible? How does too much HP bend a frame? I know thats possible but what exactly causes the frame to twist?
Old 01-15-2004, 05:51 AM   #23
Jase
Jase's Avatar
When a car launches it twists . Watch a car at the drag stip. One side of the front of the car lifts. Sometimes it does come back down. Or over time it crcks the frame or body panels ect.
Old 01-15-2004, 05:54 AM   #24
Miguel
...Delt Smash
Miguel's Avatar
so why cant you just reinforce the front of the car?
Old 01-15-2004, 06:01 AM   #25
Jase
Jase's Avatar
I am not sure I guess that might work.I still think it would cost me alot of mney to do the LS1 even if I put it in
Old 01-15-2004, 06:07 AM   #26
Miguel
...Delt Smash
Miguel's Avatar
I am not sure I guess that might work.I still think it would cost me alot of money to do the LS1 even if I put it in
what kinda parts would you need besides the engine, computer and a tranny?
Old 01-15-2004, 06:12 AM   #27
Jase
Jase's Avatar
bigger rad, drive shaft, rearend then you have to mount it
Old 01-15-2004, 06:23 AM   #28
Miguel
...Delt Smash
Miguel's Avatar
DRIVESHAFT according to the guy that installed the small block chevy motor in his E30:
My drive shaft is actually 3 shafts welded into one. Chevy trans. yoke welded to a junkyard (Chrysler I believe) shaft that is welded to the BMW rear "yoke". The BMW drive shaft is NON-serviceable. I found this out after taking the u-joint off. We found a u-joint that fit at a local auto store. My father put everything together and hit it with a couple tack welds to hold the u-joint caps in place. I used epoxy to completely secure the u-joint in place
STOCK REAREND.
Both axles had a bad cvc boot when I bought the car. It made a little noise when putting the car in drive or reverse. I made it a few thousand miles before one of the CV Joints pretty much came apart. I replaced the axle shafts with 90,000-mile axles and haven't had any problems since. I do have a 3.73 rear end to replace the 2.93 but haven't felt the need. I know the acceleration would be better but I really enjoy cruising in 4th gear below 2,000rpm on the freeway.
COOLING.
I installed a HOWE aluminum radiator with a front mounted fan..very unfortunate that there is not as much room between the water pump and radiator. The front mount electric fan pretty much rules out an air conditioning install.
Old 01-15-2004, 06:41 AM   #29
Jase
Jase's Avatar
I am going to give my friend a call tommorrow. If he still has it and offers it to me at the price we agreed It may be worth considering.Ahhhhh 6 speed 300hp e30..I still think it may be a bit harder than it seems. Where is that write up from?
Old 01-15-2004, 06:51 AM   #30
Miguel
...Delt Smash
Miguel's Avatar
right here: http://www.personal.kent.edu/~wbainey/BMW.htm
Maybe we should talk at the detroit show
