Old 01-13-2004, 04:40 AM   #1
djcontra
Gets Blown Daily
djcontra's Avatar
Where to buy Urethane bushings?
I need to replace a few of the bushings on my car really soon, including the flexdisc (guibo) on the driveshaft, so of course I'd like to simply upgrade to urethane ones so they'll last longer. Does anyone know of a company that makes things like this for a bmw e36?
thanks!
p.s. I guess delrin ones are alright too, but they're a bit harsher on the ride.
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 01-13-2004, 04:57 AM   #2
Miguel
...Delt Smash
Miguel's Avatar
OT: what does a flexdisc/guibo do exactly?
how do you know if yours is worn?
Old 01-13-2004, 05:11 AM   #3
M50E30
www.bmwclub.ca
M50E30's Avatar
A) Replace the guibo with a genuine BMW one.
B) Never use polyurethane/delerin for a guibo because you will get massive vibration!!! Thats the reason why they are made out of rubber.
A flexdisc/guibo is the rubber "doughnut" that connects your driveshaft to the transmission. And you will get vibration when it tears/breaks.
Old 01-13-2004, 12:00 PM   #4
Jon@Bimmersport
Jon@Bimmersport's Avatar
miguel..didnt u see the thing ryan gave me at his house?
Old 01-13-2004, 08:57 PM   #5
Skunk#1
go to this site they might have something. http://bmwbushings.com/
BMW--Because Mine Won
Old 01-14-2004, 12:17 AM   #6
Miguel
...Delt Smash
Miguel's Avatar
Can you be a bit more specific with the 'vibration' ???
on E34's there are no less then a bazillion things that can go wrong and cause a vibration.
Is the vibration in the front end? does it cause the shifter to vibrate wildly?
Old 01-14-2004, 04:27 AM   #7
M50E30
www.bmwclub.ca
M50E30's Avatar
I had replaced the guibo in my '73 2002 since it had a big tear in it. So you will know if it is going. So a simple inspection while the car is on the hoist will tell you if it is or not.
Where are you getting the vibration anyways?
Old 01-14-2004, 04:34 AM   #8
djcontra
Gets Blown Daily
djcontra's Avatar
I get vibration from my guibo at speeds above 150km/h, it drones throughout the whole car and shakes the floorboards. As well, I get a nice jerk forward when I shift into gear, and a minor clicking sound in 1st and 2nd gear when engine braking which is also another sign that it's bad.
Visually though, my guibo has seen better days
Mods
-Shortstack headers
-Vortech RRFPR
-Remus full catback
-SMT6 EMS (Untuned)
Old 01-14-2004, 04:48 AM   #9
Miguel
...Delt Smash
Miguel's Avatar
Im getting vibration when I go above 75km/hr, its a common problem in E34's.
...however my shifter always seems to be vibrating... Ive had that prob sinceI've owned the car. what could be causing that?
Old 01-14-2004, 04:53 AM   #10
M50E30
www.bmwclub.ca
M50E30's Avatar
Have you done the typical wheel and tire balancing? I have been told that tires have to be installed properly on a wheel (a coloured dot on the tire should line up with the valve stem hole on the wheel). But I was also told that alot of new tires are not perfectly "round" too.
Also when was the last time your shifter bushings were replaced?
Old 01-14-2004, 05:01 AM   #11
Miguel
...Delt Smash
Miguel's Avatar
Wheels and tires have been balanced and torqued correctly, im not sure about the dot though...
No clue.. probably never... I guess Ryan (Slowered) would be the authority on this one
Old 01-14-2004, 05:03 AM   #12
M50E30
www.bmwclub.ca
M50E30's Avatar
If you put your car in gear is there any/alot of play in the shifter? If so then replace 'em!
Old 01-14-2004, 05:05 AM   #13
Miguel
...Delt Smash
Miguel's Avatar
hmm.. anything else I should get if Im redoing the shifter bushings?
Old 01-14-2004, 05:08 AM   #14
M50E30
www.bmwclub.ca
M50E30's Avatar
I guess it wouldn't hurt to bring it down to Charlie (Bimmersport) at Chuck's Auto for a good tune up/inspection. He is the best out there and they won't empty out your pockets too!
Old 01-14-2004, 05:13 AM   #15
Miguel
...Delt Smash
Miguel's Avatar
Mechanically the M20 is completely finished. New timing belt, v-belts, water pump, spark plugs, tune up, coolant flush/filled (with BMW coolant too!), new K&N, + a lot of other stuff that isnt coming to my mind right now.
