Old 01-11-2004, 01:06 AM   #1
BMW_M52_M20
Damn, the 323is is out of commission......
Well today I am driving along and all of the sudden The car went out of gear and I tried putting back in and it wouldn't go into any gear. The clutch goes in and can be fully depressed without stifness or anything, the shifter will not go into an gear......
What the hell is going on, I had it towed to my mechanic and he said it may be the disc inside the clutch......
Any guesses guys? I doesn't sound like the clutch is gone or is it?
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 01-11-2004, 02:28 AM   #2
Clutch is hydrolic, so if a line is broken or leaking it wont work, just like a snaped clutch cable, but in that case you would see fluid under the car...
Old 01-11-2004, 05:24 AM   #3
98323IS
Hey Jay I saw your car at Cross Ave. Auto today man but you weren't there! Oh well. Hope everything works out okay for ya!
98323IS is offline   Reply With Quote
Old 01-11-2004, 05:28 AM   #4
BiBimBap
BiBimBap's Avatar
Yeah, let us know whut happened... we 323ers gotta stick together!
BiBimBap is offline   Reply With Quote
Old 01-11-2004, 06:43 AM   #5
BMW_M52_M20
Yeah forsure. I will let you know, I have a few things tomorrow I wanted to install, like my brushed aluminum gauge rings and M3 Mouldings.
1986 325e (E30)
Old 01-11-2004, 04:18 PM   #6
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
its probably the slave cylinder or a broken line like previously stated
UNDER CONSTRUCTION
Old 01-12-2004, 06:00 AM   #7
nseverin
nseverin's Avatar
If the Clutch plate is broken like the Mechanic says it will definitely not
let you put your car in gear. Its like having your car running in neutral and trying to select a gear. If you know how a clutch pressure plate and friction disc work you will know why.
www.howstuffworks.com
nseverin is offline   Reply With Quote
Old 01-12-2004, 06:04 AM   #8
nseverin
nseverin's Avatar
Here ya go, inc ase you didnt know.
http://auto.howstuffworks.com/clutch2.htm
Old 01-16-2004, 01:04 AM   #9
BMW_M52_M20
Well, it was the clutch plate, it was split right in two.........My mechanic also replaced the flex disc as well.
$900 with labour...........
The clutch feels a lot different now, it pops up very quick and not as stiff as it used to be. I will have to get used to it. As far as the clutch is in good running order.
1986 325e (E30)
Old 01-16-2004, 08:03 AM   #10
Jammasterj
Send a message via ICQ to Jammasterj
Jay,
Guy the same thing happend on the MX6 back in the day...the clutch got real stiff and then it just wouldn't go into gear...
You should have seen the thing, the whole plate was in 2 pieces...they were baffled...so we got it replaced under warrenty...that was the 1st out of 2 times the clutch went
Jammasterj is offline   Reply With Quote
Old 01-17-2004, 06:32 PM   #11
BMW_M52_M20
Mine was craked in three spots, my mechanic is putting it on display in his shop, lol.
1986 325e (E30)
Old 01-17-2004, 11:44 PM   #12
Soldo
Soldo's Avatar
DAMN!
Can't you put it in gear still?
I mean i can drive without using my clutch, except for starting off!
Keven Soldo
Old 01-18-2004, 08:00 PM   #13
BMW_M52_M20
Well, it's been replaced now, but at the time, the car would not go into gear with the clutch in or depressed.......Had to get it towed to the shop.
1986 325e (E30)
Old 01-19-2004, 04:30 AM   #14
dtthiaga
Similar thing happened to my buddies car. You couldn't switch gears either... so we put the car in 4th gear (while it was off)... started the car and pushed it down the road until there was enough speed to start driving it (probably not good for the clutch).
It was very late at night on a country road.. so we just drove the car straight to the mechanic without stopping....
We were debating 3rd, or 4th gear, but we had to hit the highway so 4th gear it was.
