View Poll Results: Body color glass dash!
Yes.. that would look awsome 7 33.33%
No.. but the glass rear deck and front pods. 3 14.29%
No.. it's too ricey 11 52.38%
Voters: 21. You may not vote on this poll
Old 01-09-2004, 05:56 AM   #1
Slowered318
Arrow Fiberglass E30 Dash
What do you guys think about a glass dash in my E30..
I would do matching glass rear deck, front kick pannel pods, sub enclosure and amp rack.. all painted body color and do the seats in black leather..
Feedback!
Old 01-09-2004, 06:01 AM   #2
Jase
twisted beyond reason
Jase's Avatar
I think it would look good. I was trying to do something myself with the rear deck and door pods. I want to mount subs in the rear deck but I think I am lacking the room. I havent measured yet.
Old 01-09-2004, 06:09 AM   #3
Slowered318
Jase.. there are tricks to build good speaker pods it's not that easy unless you know how. you should be able to fit a 6.5 inch down there.. as far as the rear deck it will be hard to slide a fiberglass shelf in there but i'm shure it can be done if a two piece is used.. as for subs you should try these! they are actually pretty good from what i hear.
Blaupunkt ODw1000
-Mounting depths just over 2" allows for extremely tight installations with thin subwoofer enclosures
Old 01-09-2004, 06:21 AM   #4
Jase
Jase's Avatar
You would be better off putting them in the bottom of the door. Unless you angle them toward you and up they are very inefficient. I was going to cut the rear deck and buikd a box under them. As far as building pods. depends on where.if you do the area by your feet you can pull back the carpet and fiberglass the area for a backing and use MDF for the rings and the area to hold up the ring. after you strech and staple the sheet over the ring and it is resined and dryed,area for the speaker cut out with a dremel.You can use feather fill( spray can) it sands like chalk. Prime it and paint or vinyl or fabric..done..There is more involved but it is a slight run down. I will look for a link to a website for info.
try here www.the12volt.com
Old 01-09-2004, 06:21 AM   #5
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Wanna test on mine? Its all cracked and worthless.
Stanceiseverything.com
Old 01-09-2004, 06:28 AM   #6
M50E30
www.bmwclub.ca
M50E30's Avatar
F#@k Blaupunkt! Go big with the Memphis Audio LVS Subwoofer 15-LVS18 (1000watts RMS 1400watts Peak)!
Check out this amp!!!
Memphis MOJO
RMS Power 4 ohm (Watts) 1200 x 1 @ 13.8V
RMS Power 2 ohm (Watts) 2000 x 1@13.8V
2400 x 1 @ 15.5 V
THD 4 ohm 0.75%
Frequency Response +/- 1 dB 10Hz-650Khz
Dimensions (in.) 9.75 x 2.25 x 21.5
Old 01-09-2004, 06:28 AM   #7
Jase
Jase's Avatar
the rear deck or pods?
i will help you out if i can.
here is another link
http://autos.groups.yahoo.com/group/...nscustomforum/
Old 01-09-2004, 06:28 AM   #8
Slowered318
MaxBMXr thanks for the offer.. but id be using all new material cause i hate that cheap plastic that always cracks*mad* mine just cracked today cause of the cold!
Jase.. thanks but yeah i know how to built them.. i made some fro my truck and they turned out great. i don't wanna start hacking into my doors if i can help it.. so i'm gonna slightly angle my existing 5 1/4's in the kick pannel
Old 01-09-2004, 06:30 AM   #9
85eta
85eta's Avatar
Send a message via MSN to 85eta
Sure giver a try Ryan, sounds like it could look sweet. You would certainly have a one of a kind interior! Be sure to post pics when complete!
85eta is offline   Reply With Quote
Old 01-09-2004, 06:30 AM   #10
Slowered318
Dave.. how is jase going to fit that in his rear deck. LOL.. it was just an option cause the Blau subs are extreamly shallow.. you could fit a 10" in the door if you wanted.. donno if the memphis would fit there LOL
Old 01-09-2004, 06:31 AM   #11
Slowered318
it would take me a few months to do it
Old 01-09-2004, 06:33 AM   #12
Jase
Jase's Avatar
I had plans to use come carbon fiber but i am just playing with the fiberglass for now. I have done a few things covered in C/F .The fiberglass is way cheaper.
Old 01-09-2004, 06:33 AM   #13
M50E30
www.bmwclub.ca
M50E30's Avatar
Oops! Thought you were talking about subs for the rear! My bad.
Old 01-09-2004, 06:35 AM   #14
Jase
Jase's Avatar
I was talking about subs in the rear deck . Including cutting into the deck itself. I just think I am short on distance between the rear seat and rear window.
Old 01-09-2004, 06:38 AM   #15
Slowered318
if you use every little inch.. you'll have just about 10" if your going for loud.. your better off to keep them in the trunk or port through the ski boot. ever thought of putting speakers on the sides of the rear seats.. if it's 2 door.. you have a huge empty space in there. i wouldn't cut the rear deck.. cause i think it's structural
