Old 01-07-2004, 06:23 PM   #1
Skunk#1
m3 offset bushing
for an e30 does anyone know which one this is to make the car handle better. since i wrecked the car and have to replace the rack i figured that i will replace the bushings with poly bushings. they sell kits but heard that one would use an offset m3 bushing but that was all i heard. any e30 owner done this or know other options please help. i am putting an m3 rack in the car for pointer steering and the car is already 2 inches lower than stock. thanks.
BMW--Because Mine Won
Old 01-13-2004, 01:00 AM   #2
Skunk#1
anyone?????????????????????????plz!
Old 01-13-2004, 02:19 AM   #3
Autotechnica
BMW Traitor
Get the '95 M3 front inner offset control arm bushings. It will give you more turn-in and push your wheels up closer to the front. They last way longer than the stock CA bushings, I've been told 5 years or more!
Anyways, the '96+ bushings are not offset, so get the '95 if you want better handling. I have this on my E36 right now and it's great
Good luck,
Bryan
'02 Mercedes C32 AMG 3.2L Supercharged @ 18psi - 341WHP/358lbs*ft TRQ (DynaPak) Eurocharged custom tune, ASP 178mm crank pulley + PSK, CM30 i/c pump, i/c iso kit, Magnecore wires, NW CAI, dual custom exhaust, H&R sway bars, H&R SS coilovers, KMAC camber kit, H&R spacers, Quaife ATB LSD, goodridge SS lines, Porterfield RS4 pads, AMG 18" rims, AEM UEGO wideband, Dashdaq datalogger, Kenwood Excelon DNX8120
Old 01-13-2004, 07:54 PM   #4
Skunk#1
thanks man.
