Old 01-03-2004, 02:26 AM   #1
ashvina
Question K&N Air Filter???
hey guys...
just a quick two q's.....
what sort of performance gains should a K&N air filter be giving a 93 318is?? i've done a search on the internet with mixed reviews....some ppl say that it actually reduces the power??
and secondly, on acceleration my engine emits a sort of 'hissing' noise.....is this the air filter, or sumthin else?
cheers for any help!
-ash
ashvina is offline   Reply With Quote
Old 01-03-2004, 03:26 AM   #2
Furious
BMW again.
Furious's Avatar
what type of filter? cone or flat? both will give a slight hissing sound its the air passing through it. a cone intake has a more noticeable hiss sound.
does the hiss sound fluxuate with engine idle?
Old 01-03-2004, 03:51 AM   #3
crusher
OMGHI2U2
crusher's Avatar
i have the flat filter. gives off a little bit of the hissing sound and really addictive at certain high rpm heheh
2013 Ford Focus SE
2011 Lincoln MKT
2003 Escalade 8 Seater of Fun - 251k and still running
Sold/Traded-in
2006 M5
2003 M3
2003 Civic Si
2000 M Coupe
1999 M3
1999 323i
Old 01-03-2004, 04:45 AM   #4
ashvina
yeh.... i think its a cone one. and i don't think it is present at idle.....it only starts once i start accelerating.
whats the diff between the flat and cone filter? and have you guys noticed a power difference between the stock paper filter and the K&N one?
cheers
-ash
Old 01-03-2004, 05:18 AM   #5
Autotechnica
Little Chino
If your using a cone filter make sure you make an effective heat shield. Without a heat shield the cone intake is worse than your stock airbox. A lot of people buy K&N cone filters because they growl more when accelerating. It will make a hissing sound too.
As for power gains on a "stock" motor, there's barely any. If the temperature and humidity outside is perfect, you will notice the car pulls harder at night time when the air is cool and there is low humidity. During the day driving around the city at 60km/h or less, you'll probably notice a slight power loss because your sucking in hot air from the engine. Your car will feel sluggish.
The cone filter is commonly known as the "racing" air filter setup because when your racing on the track there is a constant supply of fresh cool air from the outside. In most cases a heat shield isn't needed. But for street use, a heat shield is a must. Otherwise I suggest just using a drop-in filter.
With the drop-in filter you don't get the growl you would get from the cone filter. Another downside is the smaller surface area of the filter which is restricted by the stock airbox. A cone filter is also referred to as a free flow filter, there are no air restrictions. But protecting the filter from the heat produced by the engine is a major concern.
Bryan
Old 01-03-2004, 06:21 AM   #6
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
Send a message via ICQ to HooliGaN* Send a message via MSN to HooliGaN*
bryan you said that perfectly
took the words out of my mouth
ya autotechnica is right
depends what your going for
the k&n filter could give u two different outcomes
Julian
HooliGaN* is offline   Reply With Quote
Old 01-03-2004, 06:42 AM   #7
ashvina
cool...
so is it easy for me to "make" that heat shield...or is it a professional job??
secondly....how much $$?
cheers
-ash
Old 01-03-2004, 07:13 AM   #8
Furious
BMW again.
Furious's Avatar
your hissing sound could be mistaken as the alternator, open your hood while running and you should be able to distinguish between the two (even though they are so close together)
