Old 12-30-2003, 03:29 AM   #1
ZiMMie
Upcoming Turbo Project help/parts
Got my hands on a S4 KKK03 Turbo. can someone please give me a complete parts list(includin gagues pods etc) again. am on really really tight budget so am goin to buildin up parts in my basement until i have all the parts. I heard somethin about using 524td Manifold. does anyone know where i can find one and will it fit the m20 perfect. and will my motor internally stock, be able to handle the power from the turbo or i will need internal mods. am aimin for about 220wrhp.
any info will help execially websites/model number etc...
#E36-S54 #CSLWannabe
Old 12-31-2003, 02:16 AM   #2
328is_Perf
sounds interesting ... im just posting to keep it fresh...
The ONE and ONLY TRUE ///M3:
E36 ///M3 GTR
328is_Perf is offline   Reply With Quote
Old 12-31-2003, 02:19 AM   #3
Jon@Bimmersport
Jon@Bimmersport's Avatar
220rwhp is attainable..just make sure u save a lot of $$$ for the tuner, and dyno time.
Old 12-31-2003, 02:20 AM   #4
ZiMMie
just hope i dont spend over 800$ in parts..
Old 12-31-2003, 02:30 AM   #5
Jon@Bimmersport
oh, btw about the manifold..u can turn the stock M20 manifold upside down for it to work, and get a custom flange (pronounced with a short A sound, like FLAN-JUH lol..)made or something (heard that from randy)
you'll need a fuel pressure regulator, does that turbo have an internal wastegate?
gauge pods arent entirely necessary..save the small stuff for last, like the a/f gauge, and turbo boost gauge...u can always get those.
So..you already have:
Turbo
Manifold
You need:
Flange on the manifold to fit your turbo (t-spec can prolly make one, or randy can..costs around 400 i think)
Possibly a wastegate
Fuel Pressure regulator
Piping
Intercooler (use a stock audi or mitsubishi one since u arent running high boost)
you need a downpipe, probably 2.5"..but i think a 3" downpipe might be better
AND..a lot of $ because dyno tuning ISNT cheap.
Old 12-31-2003, 02:35 AM   #6
ZiMMie
Turbo
Manifold
You need:
Piping
For the wastegate and Fuel Pressure regulator i cant find one that is made for e30s. is there a company that makes a universal one for all cars?
Old 12-31-2003, 02:42 AM   #7
Jon@Bimmersport
vortech makes to pressure regulator...universal i think....wastegate is for the turbo..not the car
Old 12-31-2003, 02:57 AM   #8
Jon@Bimmersport
oh, u might need injectors too
Old 12-31-2003, 03:35 AM   #9
EMPOWERD
EMPOWERD's Avatar
Getting good grasshopper... couldn't have said it better myself. Bump up the fuel pressure with a B&M adjustable fuel regulator and get a Cartech/Vortech FMU. You might have to upgrade your intank fuel pump to a (so I hear) E28 535i pump. Stock injectors will probably be okay if you don't run over 7psi.
My YouTube video
-- RANDY SPARRE --
Old 12-31-2003, 03:36 AM   #10
ZiMMie
so how much psi do i need to run to get 220rwhp?
Old 12-31-2003, 03:45 AM   #11
Jon@Bimmersport
every PSI is roughly 10-15hp..im not sure on ur turbo, but thats what i been understanding...but im sure thats 10-15crank hp..
so our M20s got 170 stock... say 13psi x 7psi to maintain stock injectors, is 91hp..crank.
170+91 = 261hp at the crank..friction loss is 15%..so..
261hpx.15 = 39hp
261hp-39hp (friction loss) = 221hp
you should be at your goal with 7hp...give or take 10hp u wont feel a difference....adding PSI isnt the only way to add power. you generally have a stock head. one thing to improve power is a throttle body being bored out, or getting a light weight flywheel increases your power being put to the ground, and less friction loss. I'd suggest getting a stage 1 clutch once yours goes..and light flywheel at the time. I dont know how to stock diff will hold up...but put some redline oil in there, and make SURE when u run the turbo you use really good oil. Oil is what cools the turbo too, and the install should be done right...since its custom, all the placing should be good since gravity is what gives the turbo the oil...small things like blow off valves, gauge pods, turbo timers can all be added later. concentrate on the essentials first if your on a budget and try not to get sidetracked with accessories.
Old 12-31-2003, 03:50 AM   #12
ZiMMie
thanx jon didnt know u were that smart. lol
the only B&M adjustable fuel regulator i can find on ebay is for integra/civic. will it be same for the m20?
Old 12-31-2003, 03:59 AM   #13
Jon@Bimmersport
I'm guessing its universal..the Holley one is..since they have no specific application..because of custom kits, and prebuilt kits..etc.
it doesnt attatch to the motor itself so i guess it wouldnt matter...i think it goes somewhere near the fuel rails...
heres the holley one...
click here
Old 12-31-2003, 10:16 PM   #14
808BMW
Good luck. Put aside AT LEAST $1000-$2000 for a turbo. $40 well spent is Maximum Boost by Corky Bell. Read it through and you dshould have a good idea on turbocharging.
808BMW is offline   Reply With Quote
