Old 12-29-2003, 04:33 PM   #1
Cool sickest mother****er to walk the earth....
Im truly speechless....
Old 12-29-2003, 04:50 PM   #2
Lil'Smoothie
Guest
Posts: n/a
jeeeeze that is disgustingly siiiiiiick guy
Old 12-29-2003, 05:08 PM   #3
Soldo
Soldo's Avatar
mmmmmmmm, i don't understand how people can NOT like te 8er, that car was way ahead of its time!
Keven Soldo
Old 12-29-2003, 05:34 PM   #4
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Send a message via MSN to AlpWhitE46
I think he meant it in a good way soldo..lol
oh and btw..he doesent walk the earth...he rolls the earth
AlpWhitE46 is offline   Reply With Quote
Old 12-29-2003, 06:37 PM   #5
Slowered318
i hope the 8 series doesn't get "bangled up"
Old 12-29-2003, 06:45 PM   #6
1BADBMW
1BADBMW's Avatar
did you guys watch the italian Job, there was a sick 850i with deepdish in it!!! something like the 1 in the picture!!!
1BADBMW is offline   Reply With Quote
Old 12-29-2003, 06:47 PM   #7
Soldo
Soldo's Avatar
REALLY!
lol, i know that jack ass, i meant that as a general comment, quite a few people don't like the 8er design!
CRAZY IF YOU ASK ME!
And the 8er in the italian job had M parallels on it!
Keven Soldo
Old 12-29-2003, 07:03 PM   #8
Slowered318
speaking of itallian job..
Monster car garage tonight 9pm... super MINI snowmobile
I'm counting back the hours
Old 12-29-2003, 07:57 PM   #9
AndreNY
AndreNY's Avatar
its nice but def not the sickest
Down and Out that's the way to go...
AndreNY is offline   Reply With Quote
Old 12-29-2003, 08:23 PM   #10
SeRb
Don't shrink me Gypsy!
SeRb's Avatar
those are the mks again right?
hehehe
love those ****in rims
still looking for a nice photo where they're poloished
SeRb is offline   Reply With Quote
Old 12-29-2003, 10:18 PM   #11
AMG_POWER
500HP Member
found somewhere on the net.....
When creating the 850CSi's S70 V12 motor, BMW Motorsport began with the standard 24-valve SOHC M70 engine and instituted the following changes:
-Increased bore (from 85mm to 86mm) and stroke (from 79mm to 80mm) for a new total displacement of 5,576cc (from 4,988cc)
-Lighter pistons
-Increased compression (from 8.8:1 to 9.8:1)
-More aggressive valve timing for increased high-rpm power
-Larger diameter exhaust pipes
-Variable rpm limit (6,400 in 1st+2nd, 6,200 in 3rd, 6,100 in 4th. 6,000 in 5th+6th)
-Adjustable throttle sensitivity via dual mode (Sport or Komfort) console-mounted switch
-Engine oil cooler (European-spec models only)
These modifications resulted in an increase in maximum power from 300 hp (DIN) or 296 hp (SAE) at 5,200 rpm to 380 hp (DIN) or 372 hp (SAE) at 5,300 rpm. In addition, maximum torque was increased from 332 lb/ft at 4,100 rpm to 402 lb/ft at 4,000 rpm.
This engine can be identified by the "Powered by M" inscription on the central cam cover between the two banks of cylinders.
What kind of gearbox does the 850CSi have?
The sole gearbox offered for the 850CSi was the Getrag Type E six-speed manual with the following ratios: 4.25 (1), 2.53 (2), 1.68 (3), 1.24 (4), 1.00 (5), 0.83 (6). This is mated to a 2.93:1 rear end with limited slip differential. In addition, Automatic Stability Control plus Traction (ASC+T), which can apply the brakes and/or reduce engine power in the event of traction loss, is fitted as standard to the 850CSi. Finally, European-spec models are equipped with a transmission oil cooler."
AMG_POWER is offline   Reply With Quote
Old 12-30-2003, 12:19 AM   #12
windsor318is
Nitrous Junkie!
windsor318is's Avatar
did we ever get the csi here in canada with the 380hp, 6 speed???? i dont think so eh...........
Old 12-30-2003, 03:28 AM   #13
1BADBMW
1BADBMW's Avatar
850CSi....eh? ... eh?...yummy..eh?
Old 12-30-2003, 03:31 AM   #14
1BADBMW
1BADBMW's Avatar
uuhhhhh!!!...
Old 12-30-2003, 03:33 AM   #15
WhadUpp
BIG BIG WHEELS
WhadUpp's Avatar
The 850csi is a magnificent example of a BMW that was ahead of its time over a decade ago. Its design is better than anything Bangle has been able to muster . A true work of art and engineering in its heyday that still looks beautiful even by todays standards.
'Good judgement comes from experience. Unfortunately, the experience usually comes from bad judgement'. - from an Australian Aviation Magazine.
WhadUpp is offline   Reply With Quote
