Old 12-24-2003, 07:42 PM   #1
BMWjACkER
Registered User
Car is Choking?
Hey
Any 1 know why my Car would choke when adding the Throttle very fast? Timing? right know i'm going to add some injecter cleaner flued... I had time proble before and it when away tell now... Any one come across this problem before? Thanks
BMWjACkER is offline   Reply With Quote
Old 12-24-2003, 10:05 PM   #2
Jon@Bimmersport
Jon@Bimmersport's Avatar
i have this problem too...only under like 2500rpm though if i give it a bit of gas it chokes...also my car SHAKES a lot when idling.
fuel pump? i hope not!
Old 12-24-2003, 10:42 PM   #3
BMW jacker, honest to god, when i bought my 533i i had a problem like yours(well kinda, i stalled it once, and then after that, it would choke when sitting at idle), and redlining 2,3, and 4th gear helped it. i think it was just clogged hoses or something, but it never EVER stalled again. I also, had this electronic gremlin, when the car would be driving normally, and all of a sudden, it would feel like im not pressing the gas properly, or the fuel has been cut off, and then it would go back to normal after a few seconds, and then do it again, but that was only when cruizing. When gunning it, that problem never occured. Basically get all the shit out of it by taking it all the way to the redline!!!ITS FUN, TRUST ME!!! Just make sure there is no cops around you first.....
Old 12-24-2003, 11:08 PM   #4
Jon@Bimmersport
terry i redlined my car about 394578863 times today and it didnt do shit.
Old 12-25-2003, 01:00 AM   #5
BMWjACkER
Registered User
REDLINE:(
I just got a chip for my ride and I've been beating the f@ck out of it, pushing it a little too far, now when I put the peddle to the floor i't chokes, " only if I do it fast" may be not enough gas coming in......
Old 12-25-2003, 05:35 AM   #6
Jon@Bimmersport
i redlined it like terry said over and over (while feeding it to the new RX-8!!) and it did help, im using some system cleaner too about 2-3 times over
Old 12-25-2003, 06:17 AM   #7
crazyvadim
crazyvadim's Avatar
Re: Car is Choking?
Originally posted by BMWjACkER
Hey
Im thinking leaking or dirty injectors,do you get a check engine light??
Old 12-25-2003, 06:21 AM   #8
crazyvadim
crazyvadim's Avatar
sounds like a bad throttle position sensor
Old 12-25-2003, 06:49 PM   #9
that car's gone man....
Old 12-27-2003, 02:56 AM   #10
Jon@Bimmersport
where can i check mine? my car spudders while driving at half throttle sometimes...and even at idle it does...the car SHAKES like im gettin it on with someone
Old 12-27-2003, 04:51 AM   #11
BMWjACkER
Registered User
Problem fixed, too much oil..... duhhh
Old 12-27-2003, 07:48 AM   #12
crazyvadim
crazyvadim's Avatar
No Check Engine lights?? A bad TPS will affect ignition timing,fuel metering and it can give u many trouble codes.You can test one by measuring the voltage drop across the sensor at different throttle positions,check your service manual for more info since im not really familiar with BMWs.....i try helping you german import guys the best i can.
Old 12-27-2003, 04:13 PM   #13
BMWjACkER
Registered User
Man it said to check every thing, I don't look at that any more I get scared.
Old 12-27-2003, 04:24 PM   #14
Quack
Wheelman
Quack's Avatar
my car shakes when I floor it, but I figured it out what it was, my cats were clogged to shit, going to get a whole new exhaust system next week
Old 12-27-2003, 04:27 PM   #15
Quack
Wheelman
Quack's Avatar
Jon is the car misfiring, my car was ok, but when I rev it over 3500 it shakes, during idling also, my cats were causing the problem
