Old 12-24-2003, 03:48 PM   #1
objec
Send a message via AIM to objec
1987 e30 325e start up problem? need help!
my car usually starts, now that it has been getting cold, and when i go to start it sometimes, it wont. so ill the put the key in and turn, the engine cranks and sound like its going to start, but it wont. so i let it sit for an average of 6 to 12 hours then try again. every time after letting it sit, it starts right up like it normally does. can anyone help me or have suggestions?
objec is offline   Reply With Quote
Old 12-27-2003, 01:20 AM   #2
DORIGTT
If you have a service manual, I would go through the list of troubleshooting procedures to find the source of your malady. Just a wild guess, try checking the coolant temp sensor that supplies the fuel injection to see if it is reading correctly or not. I had a similar problem and tracked my starting ills down to that. Or you may want to turn your key on to run position and depress the accelerator fully 5 times and wait for the computer to put out the trouble codes to find the problem that way.
Oh, make sure you have fuel "It's outta gas...umm hmph"
DORIGTT is offline   Reply With Quote
Old 12-28-2003, 06:29 PM   #3
boosted325
Send a message via AIM to boosted325
i had that problem last winter, but i then discovered if i jus let the car sit for aout 35-60secodns it starts up, i sometimes still have that problem, which leads me to think i have a faulty cold start injector, or thermo time switch.. check those 2 out
85 325e turbo project
- large cone filter
- larger bore TB
- single cherrybomb muffler
- a/f guage and carbon fiber shift knob.. more guages to come
boosted325 is offline   Reply With Quote
Old 12-29-2003, 03:10 AM   #4
KC Ron Carter
Hmm,
Fuel pump check valve.
I could replaced the fuel pump for $200 but I fixed the problem by putting in the fix from BMW for about $3.50,
part # "16 14 9 068 988"
Now the engine starts on first turn, hot or cold, overnight or after
standing for a while.
Diagnosis:
The check valve in the main fuel pump was leaking allowing the fuel injector rail residual pressure to bleed off resulting in formation of a huge fuel vapor bubble in the fuel rail and back down the fuel line toward the pump.
The extra cranking time was needed by the fuel pump to recompress and eliminate the fuel vapor bubble in the line and repressurize the fuel injector rail.
Installation can be anywhere in the fuel pressure line but next to the main pressure pump is best.
It is a two screw clamp job.
Later,
KC Ron Carter is offline   Reply With Quote
