Old 12-26-2003, 08:32 PM   #46
Autotechnica
Little Chino
Mystikal,
I hope your comparing Bilstein Sports with Koni Adjustables. Because Bilstein heavy duty's are often mistaken for Bilsteins top line of dampers.
Bilstein only makes the "Sport" damper for a small selection of automobiles. If you look at Bilstein's catalog, all or most Japanese imported cars only have Heavy Duty dampers available and not the Sport. Heavy Duty is best for stock or slightly lower springs, which is what the quotes you provided suggested. Could this be the one you're talking about? In this case, most owners of Japanese imports will definitely choose Koni over Bilstein as they have the sportier and stiffer shocks. For E36, I have heard nothing good about the KONI dampers, but only good things about Bilstein Sport. Some people on BMWPlanet a while back even complained that the KONI's were too stiff for street use, and that the shock travel was too short so they were bottoming out. Bilstein recommends you do not use HD dampers for lowered springs, therefore if E30 owners only have the "HD" dampers availble to them, it would explain why they blow in less than a year.
Bilstein Sport/Heavy duty shocks have been used on BMW's for many years. I think your letting your obsession with slamming your car get to you. It's a good thing to lower your car a little for the street. But if it's not a full out race car I don't see the point. Lowering the car too much puts A LOT of stress on the chassis and suspension components.
Bry
Old 12-26-2003, 09:33 PM   #47
Originally posted by Autotechnica
Mystikal,
I am fully aware of the difference between HD and Sport models.
They are both available for the E30. The Sport is much more popular, and the one I am referring to in my posts.
Who said anything about my car? The point of the thread is tips for Jon, and if you have seen his car (and I know you have), it's tucking all 4 tires. Because of his needs, I'm telling him that Koni's are best suited for him.
Old 12-26-2003, 10:33 PM   #48
Autotechnica
Little Chino
I said that because you said any E30 with good springs stiffer or lower than Eibachs shouldn't use Bilsteins, and you said for that reason Bilsteins are no good for E30s. Which would suggest that you think Eibach's aren't good springs and that only springs that lower your car more or are stiffer than Eibachs are good. My point was that lowering your car too much isn't appropriate for street use, therefore, Bilstein's work just fine w/ street/track setup. If you want to use "race" springs, use race dampers like Koni.
I know this thread is about Jon's car. However, I'm not convinced that KONI makes better dampers for lowered springs than Bilstein does.
Bryan
Old 12-27-2003, 12:01 AM   #49
NickP
NickP's Avatar
e46lover - What spring rates are you running on the OBX's?
Old 12-27-2003, 12:05 AM   #50
Jon@Bimmersport
Jon@Bimmersport's Avatar
i am not sure, i got them off of M50E30..so he would know i guess?
Old 12-27-2003, 01:14 AM   #51
ROBM3
ROBM3's Avatar
Send a message via ICQ to ROBM3
The obx spring rates are like 150-200lbs I'm guessing.
ROBM3 is offline   Reply With Quote
Old 12-27-2003, 03:27 AM   #52
M50E30
www.bmwclub.ca
M50E30's Avatar
Not a clue little buddy. I will be going to FK Konigsport coilovers and have them set up properly for each event (BMWCCC @ Mosport, AutoX, and street).
Old 12-27-2003, 03:45 AM   #53
Jon@Bimmersport
autox? so i guess ill be seeing u this spring at the autox's?
Old 12-27-2003, 04:20 AM   #54
M50E30
www.bmwclub.ca
M50E30's Avatar
Depends on how much of a deposit I have for the house come spring time. If I can afford to keep the E30 and a house then I will be there with bells on!
Old 12-27-2003, 04:22 AM   #55
Jon@Bimmersport
awesome..ill be there too..without the bells though
im going to get the car raised a bit (since my stupid bro cant even drive a lowered car) and corner weighed...then ill post up if i still got a problem
Old 12-27-2003, 07:21 AM   #56
EMPOWERD
EMPOWERD's Avatar
i believe the spring rates on the OBX are 275lbs and 350lbs.
My YouTube video
-- RANDY SPARRE --
Old 12-27-2003, 11:47 PM   #57
BMW_M52_M20
alignment in the summer when i got a new steering rack...the shocks were put in this spring
My steering has always been loose, not at all like the e36, I thought the new steering rack would tighten it up?
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 12-28-2003, 09:14 AM   #58
aaron_silva
That is very, very soft.
Aaron Silva
1991 318iC
aaron_silva is offline   Reply With Quote
Old 12-29-2003, 01:55 AM   #59
Jon@Bimmersport
i was told it is just a bit off from the normal GC rates...
they are nice for now, once i add all the rest of the suspension components and still want a stiffer spring (useless for street use) then i can just swap springs..i dont need to buy expensive ground controls for no reason.
