Old 12-18-2003, 01:33 AM   #1
BladeRunner
BladeRunner's Avatar
Is this normal?
Tuesday, I think it was, I was out driving about and reached a speed of more or less 75MPH (like 115KPH I think) and my car started bouncing. Now she doesn't always do this but on occasion she does. If this maters I have power steering disabled. I figured this could be because of one of the following:
1. Bad alignment
2. Worn out suspension system
3. Bad tires
4. Just the lightweight of the car.
5. Result from power steering delete
6. My car has been raised 1-3" in the rear or lowered 1-2" in the front (done by previous owner).
Do you have any ideas as if this is normal, and if not a possible cause?
Thanks in advance.
BladeRunner is offline   Reply With Quote
Old 12-18-2003, 01:39 AM   #2
BeemerBuddy
buddy your car sounds scary, i would take it to a LISCNECED mechanic and have it evaluated....
BeemerBuddy is offline   Reply With Quote
Old 12-18-2003, 01:43 AM   #3
Justin e36
Justin e36's Avatar
alignment / tires / bent rims... most likely though, bent rims... happen sometimes because it depends on where the bend is on the left rim, and the right rim.. when they're both at their worst... you get vibration, but most of the time not really... your ball joints likely need replacing too. Happened to me before. (and I didn't notice wheel vibration or anything otherwise...)
Old 12-18-2003, 01:52 AM   #4
BMW_M52_M20
I think it is probably worn suspension and that it is a lightweight car, I need new shocks and it does the same.
jay
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 12-18-2003, 01:58 AM   #5
Mitch555
Retired MaXmember!
Mitch555's Avatar
Have you driven on the same road at the same speed before?
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
Mitch555 is offline   Reply With Quote
Old 12-18-2003, 02:05 AM   #6
BladeRunner
I travel that same interstate everyday almost and there are few dips or bumps. I useually drive about 60-65MPH.
Mad E30 lover
Old 12-18-2003, 03:03 AM   #7
crazyvadim
crazyvadim's Avatar
check springs and shocks.....must be a pretty worn suspension,better be safe then sorry.
Old 12-18-2003, 05:15 AM   #8
BladeRunner
Dern there goes another $600. I told my parents. They don't listen to sh** I say. Engine, Exhaust, Paint, Suspension, Tires, nothing. Well thanks.
