Old 12-16-2003, 07:47 PM   #1
Albertae30
Albertae30's Avatar
what could be making my car idle up and down
i have a 1984 318i and rebuilt motor . the rpm gauge shows that my car idles up and down a little yet never stays constant. the gauge maybe moves 2mm at most yet you can feel it what could this be.and what could i do to fix it .
thanks ahead of time
1995 VOLVO 850 Turbo
1986 Chev Camaro Z28 running 250 horse with just a stock motor and open air filter carbed.
allcanadianreject84@hotmail.com
Albertae30 is offline   Reply With Quote
Old 12-16-2003, 08:08 PM   #2
theblue
old school US member.
theblue's Avatar
Send a message via AIM to theblue
that first place I would start is check the fuel filter.
08 Corvette LS3 // 89 325is w/ M50 swap // 06 Audi A3 (stg 2) // 07 VW EOS (stg 2) // E36 Chumpcar
theblue is offline   Reply With Quote
Old 12-16-2003, 08:38 PM   #3
8500 RPM
BMW = Big Money Wasted
8500 RPM's Avatar
alternator? low charge??
8500 RPM is offline   Reply With Quote
Old 12-16-2003, 09:01 PM   #4
djcontra
Gets Blown Daily
djcontra's Avatar
I've battled this problem on my E36, but the same things can happen to the E30 as well:
1. Idle Control Valve (make sure it's clean, connected, and the arrow on it is pointing up)
2. Air Flow Sensor (make sure it's not upside down)
3. Check for air leaks, and vaccum leaks
4. Clean your air filter
5. O2 sensor (I check this one last because it's an expensive part)
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 12-16-2003, 10:55 PM   #5
Justin e36
Justin e36's Avatar
had this problem until a few days ago... changed my voltage regulator. If you notice your lights flicker a bit too... then I'd say this is likely the prob.
But check your ICV, Air Flow Sensor and Air Filter first.. (as djcontra said...)
Old 12-17-2003, 06:45 AM   #6
Albertae30
Albertae30's Avatar
well see i had my whole engine out during summer when i did my rebuild and i also just installed new alternator. thus when doing this i had to take off my air box and what not. so i will check the air flow meter first then for leaks hopefully i find it thanks guys.
Old 12-17-2003, 09:18 AM   #7
Bas325
Hi,
I have the same problem with my 325i E30 and I found that this only happens when I turn on more electrical devices.
So my guess is to check also if it is possible to install a bigger battery for instance a gel battery.
Bastiaan
Bas325 is offline   Reply With Quote
Old 12-17-2003, 09:48 PM   #8
crazyvadim
crazyvadim's Avatar
check the alternator
Old 12-17-2003, 11:42 PM   #9
Soldo
Soldo's Avatar
See ihaven't checked all of this stuff, but i notice that my IDLE starts BOUNCIN sometimes when i apply the brakes, moderately enough to stop, what the hell can that be from?!
Keven Soldo
Old 12-17-2003, 11:42 PM   #10
BladeRunner
BladeRunner's Avatar
I thought this was normal when i got my car it idealed between 500-1000RPM. However, now with my burnt cat (don't tell anyone IE: popo, gov, EPA I told you that) my car now ideals at 750-1150+/-RPM.
Getting off the subject I feel that my car has a little more get up and go and the heater get hotter faster.
Getting back on subject in the Bently Service Manual, I have, it reports the following ideal speeds 318i (84-85) 750/850+/-50 RPM, 325, 325e (84-87) 700+/-50 RPM, 325,325i/is/ic (88?) 720+/-40 or 760+/-40 RPMBut if your worried check your idle control thingies.
If you don't mind me asking how did your rebuild go and what was replaced/rebuilt?
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 12-17-2003, 11:46 PM   #11
BMW_M52_M20
Had the exact same problem, It was the air boot coming from the mass air flow sensor to the manifold, there was a hole in it.....Also check the idle control valve.......
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 12-18-2003, 09:26 PM   #12
97 Z3 2.8
I too think this sounds like a vaccum leak issue.....
Bill
Bill
1997 Z3 with N/A power adders....
97 Z3 2.8 is offline   Reply With Quote
Old 12-18-2003, 11:19 PM   #13
sonic07
sonic07's Avatar
i used to have that problem too after installing the Dinan chip and BMW dealer mechanic told me it's the idle control valve needs to be clean or replace. it would happened when the engine is hot especially after racing around. where the idle control valve is located it's a bitch to get at but for some strange reason the problem went away after a week later and never come back until now.
Pedal To The Metal
sonic07 is offline   Reply With Quote
