12-04-2003, 08:24 PM
#1
Car: 1997 Jetta GLX VR6, 1998 BMW E36 323is {M52}(SOLD!), '04 e46 325iT (pops), '86 e30 325e {M20}(My Classic),
E30 is running like a dream now......
Well, my 325e has been running alright since I bought it but there was a few things that were concerning me like poor gas mileage and rough starts......
Anyways, I got it back from the shop today and had a few things done:
1) New OEM Cap and Rotor
2) 6 new spark plugs
3) New Air flow boot (It was cracked casuing my engine to rev up and down)
4) New Flew disc
5) New T valve (my drivers side washer weren't working)
6) My steering wheel had play, and is tightened
Now the car runs so so much better
I had a look at the cap and the contacts had corrosion on them and my spark plugs were very fouled which meant my car was running rich.....
My engine always used to "Hunt" at idle and would rev up and down, but it was the cracked air boot which was casuing it, and the new flex disc has really smoothed out my gears, used to be very rough and touchy when hitting the gas.....
I can't believe the power difference, just so much smoother and starting it up now is no problem.......
Well worth the money spent on the car, thought I would post if anyone was having similar problems with there e30......
Cheers
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
12-04-2003, 08:39 PM
#2
Car: AA S/C E46 M3
before u fixed that disk..if u were at like 3000rpm in 1st and let off the gas did the whole car jerk and lean forward?
Authorized Ontario dealer for Active Autowerke|VF-Engineering| AFE| Bilstein Suspension| H&R Suspension| KW suspension| Brembo Brake Systems| Stoptech| - Call us for the best pricing
12-04-2003, 08:42 PM
#3
Jon,
Yes that is exactly what was happening, if I would let off the gas even gently or push the gas gently mainly in first and second gear, it would do that......
If yours is doing that, it probably is the flex disc, it is a rubber part that wears out over time......It is cheap to like $40.00......
Makes a BIG difference......
1986 325e (E30)
12-05-2003, 01:41 AM
#4
Car: AA S/C E46 M3
Where is the flex disc? and how much is install? thanks jay, u dont know how much time this saved me! lol
if u let the clutch out a bit too fast or dont put enough gas in...does the car make a "thunk" ?
12-05-2003, 02:00 AM
#5
Yeah man that is exaclty what happens......The flex disc is located in the driveshaft........It is an easy part to replace if you have the right tools and location to work on it......I don't, I know the flex disc was 40.00$ as for the labour, on my bill, I just have a total of hours of labour spent on the car......I will ask my mechanic and PM you tommorrow.......
1986 325e (E30)
12-05-2003, 02:03 AM
#6
Nitrous Junkie!
Car: 91 e30 318is,96 328is
hhhmmm i think i better check my air flow boot, ive always had a funny idle though..... jon what do you mean my the car leaning forward???
jay i too would like to know the same about the flex disk, if its easy enough to fix, for that price i might as well change it
12-05-2003, 02:11 AM
#7
Okay guys, here is what I noticed in my car:
In first or second mainly at low RPM's but enough that there shouldn't be lagging, it felt very touchy, it would make Cluncks and would tend to lean forward a bit almost as if you had the clutch out but weren't giving it enough gas and it was bunny hoping, although I knew I was giving it enough gas......
Say at 2000 rpms in second gear I would let go of the gas to put on the brake and clutch and it would clunck and hop depending on certain speeds........
I bet you it probably hasn't been replaced in either of your guys cars, would be interesting to see if your flex disc's are worn out, mine was shot, and man, the car is much more smooth........
Good luck,
I will let you guys know on how much for labour, I remember my mechanic saying it wasn't difficult........
Here is a pic of a flex disc for my model, pretty much the same as your guys.....
1986 325e (E30)
12-05-2003, 02:31 AM
#8
Car: is not a real ///M5
id like to know as well please.
www.enthusiastauto.caContact if you are looking for a car
His--2000 BMW ///M5 .:Jet Black on Black:. Individual - Style 65 Wheels; 9.5" Square Set up;275 Tires;10mm/3mm Spacers; Black Kidneys;Muffler Delete; 3.5" Dual Tips; Beast Power Sway Brackets; "Dinan" Ducts; E60 SSK; BC Coils
Hers--2000 BMW ///M5 .:Avus Blue on Grey/Black:. '01 Exterior Upgrades; E60 SSK
12-05-2003, 02:33 AM
#9
Alright, check this thread around 10am tommorrow and prices will be up......
1986 325e (E30)
12-05-2003, 02:38 AM
#10
woudl that be eastern time, or pacific?
12-05-2003, 03:14 AM
#11
Car: AA S/C E46 M3
thanks jay, thats exactly wat happens, LOW rpm going around my street..it is SO annoying like i got a .1324lb flywheel lol
12-05-2003, 07:46 PM
#12
Alright guys, it is about an hour of work.......so for me, 72$/h plus 40.00$ plus taxes =
$128.80 with labour and taxes.......Would be good if you good do it yourselves.......
1986 325e (E30)
12-05-2003, 10:10 PM
#13
Car: 1991 318iC
You said you fixed the play in your steering wheel. What exactly was the problem and how was it fixed?
Aaron
Aaron Silva
1991 318iC
12-05-2003, 10:31 PM
#14
Car: AA S/C E46 M3
Aaron
i'd like to know too..my steering doesnt react right away.
12-06-2003, 05:12 PM
#15
Car: 2000 540i
wow, i have the same problems, thought it was just me, especially the flex disc.. if anyone in the toronto area goes and gets this fixed on their e30 pls let me know where you did it and how much it cost you, this problem is really starting to piss me off exactly the stuff e46lover was talking about
