Go Back   maXbimmer Forums > Multimedia > Videos and Sound
Old 12-04-2003, 01:56 AM   #1
Jon@Bimmersport
Jon@Bimmersport's Avatar
For anyone who hasnt seen Dado's beast..
right click and select save target as
during the day he runs 10.5PSI and at night it is 14.5PSI..his car can go to 18PSI roughly on 104 octane gas..lucky mofo
Old 12-04-2003, 01:58 AM   #2
BlitzSix
6 Speed
Send a message via AIM to BlitzSix Send a message via MSN to BlitzSix
He's racing a Supra, right?
What setup does that biznitch have?
BlitzSix is offline   Reply With Quote
Old 12-04-2003, 02:10 AM   #3
Jon@Bimmersport
dado? or the supra? the supra has a t-51 turbo i think. ill post dado's mod list in the next post
Old 12-04-2003, 02:15 AM   #4
Jon@Bimmersport
Chasis: 1995 BMW M3
Engine:
Active Autowerkes Stage 3 Turbo Kit
AA Custom 3.2 M Motor Built
Stage 3 1400 CFM Intercooler
Stage 3 Hybrid Turbo: 60-1 compressor end mated to a clipped TD06 exhaust end
Pauter rods chromoly rods
JE Pistons 8.3:1 motor
AA Turbo Spec Cams
Knife edged crank
Hi performance valve springs
Dual electric 10” fans
Heat Wrapped exhaust manifold and piping
HKS Racing Bypass Valve
HKS Racing External Wastegate
Greddy Boost Controller
Greddy Turbo Timer
AA Water/Alcohol Injection System
ZM Coupe radiator
MSD D164 ignition system
AA Custom 3 inch exhaust
AA Custom 3.5" Low Level Air Intake
Custom tuned at Active Autowerke in Miami
Last dynoed in October 2003 at Altered in Gaithersburg and it made 458 hp to the wheels at 17psi. At 11 psi it made 385 to the wheels
Transmission:
Active Autowerke aluminum lightweight flywheel
Active Autowerke 4 Puck Racing Clutch
Evo M3 6 speed Transmission
2.93 Differential with 40% lockup
AA Shift Knob
AA Short shift kit
Suspension:
KW Coilovers Variant 3’s:
Independently adjustable rebound and compression damping
Inox-line stainless steel technology
Individual height adjustment
Infinitely adjustable rebound damping
14- level adjustable compression damping
BMW X-Brace
Active Autowerke Rear Toe Bushings
Active Autowerke Rear Camber Correction Arms
Lighting:
BMW Clear Lenses
ZKW European Ellipsoids with lightnings enhanced from Umnitza
8,500 K Low beam xenons
8,500 K foglight xenons
Wheels:
Kinesis K58 18X8.5 front
Kinesis K58 18X9 rear
Falken 451 235/45/18 front
Falken 451 255/35/18 rear
Exterior:
Rieger Carbon Fiber front splitter
BMW LTW M3/GT Rear Wing With Removeable Height Extensions
Painted Moldings, door handles, washer nozzles
Full paint Ferrari Code #102
Full front end 3M paint protection film
Brakes:
Stoptech 14 inch front with Hawk blue racing pads
Stoptech 13 inch rear with Hawk blue racing pads
Interior:
Stack ST8110SR Boost Street Dash it has:
Tachometer
Boost Pressure in PSI
Speedometer
Odometer & Tripmeter
Oil & Fuel Pressure readout
Water & Oil Temperature readout
Volt Meter
Fuel Level
Infrared Lap Timing
Predictive Lap Timing
Sparco Suede steering model 323
Sparco quick release hub
Sparco horn kit
AA E-brake handle
DAS Sport full welded in cage
Nerf padding
Fully gutted
Teamtech 5 point harness with camlock
Cobra Evolution Technology GT Seats full carbon fiber drivers seat
Cobra competition side mounts
Cobra sportline for passenger
and heres a pic..it is just the way i'd want it..maybe a different colour though.
Old 12-04-2003, 02:17 AM   #5
BlitzSix
6 Speed
Yeah I was talking about the Supra..
T-51... that's not a turbo to be draggin with.
Slap a T 88 on that biznitch and he will walk Dado like he was standing still (in the straights, that is).
Dado's car is pretty sweet though
Old 12-04-2003, 02:19 AM   #6
Jon@Bimmersport
maybe...but in that vid dado didnt do more than 14.5PSI..so, you still have till his 17PSI..and it all depends on weather too..hotter temp = shitter power..they're in washington, it gets pretty hot there..im not sure about this time of year though, that vid was in like nov or something..also, dado's car weighs maybe 2900lbs now or so..maybe 2800...supra is around 3400. so the supra maybe needs 550-625RWHP..which isnt a problem, but for M3 thats impressive..a lil behind impressive
Old 12-04-2003, 02:23 AM   #7
///MsAniTy
hey y doesnt the hole video download?
///MsAniTy is offline   Reply With Quote
Old 12-04-2003, 03:13 AM   #8
tiestoE36
tiestoE36's Avatar
he got the 95 m3 b/c its is the light weight body right.
tiestoE36 is offline   Reply With Quote
Old 12-04-2003, 03:15 AM   #9
BlitzSix
6 Speed
And isn't 95 also easier to mod cause of they OBI thing ?
Old 12-04-2003, 03:20 AM   #10
tlaselva
1800+ HP Driveway
tlaselva's Avatar
That's got to be one of the best E36's built.
Must've cost well over 100G's CA to built it ....
2011 X5 M-Sport 3.5i
2010 Dodge Ram Hemi Sport
2010 GSX-R 750
2003 C5 Z06
903rwhp/815rwtq : 10.3@152mph
Old 12-04-2003, 03:30 AM   #11
jeremy
must be nice to have that kinda coin !...........pimp ride !
Old 12-04-2003, 03:30 AM   #12
tiestoE36
tiestoE36's Avatar
but i though he bought the 3.2l engine with aa turbo as a compete set up. doesnt that mean its ob11
Old 12-04-2003, 03:31 AM   #13
tiestoE36
tiestoE36's Avatar
a complete kit like this.
Old 12-04-2003, 03:46 AM   #14
Jon@Bimmersport
the 95 M3 is OBD1..no matter wat motor u put in it HAS to be the same as the car..
edit: tiesto..the light weight body is only on the LTW M3 consisting of no stereo head unit, alumiunum doors, trunk and hood i think.
Old 12-04-2003, 04:18 AM   #15
tiestoE36
tiestoE36's Avatar
i thought, probably wrong thou, that the obd, is teh comp that controls the engine and so on, i just thought that one you change the engine you change the comp too.
but i guess its the same as doing swap from obd2 to obd1.
