Old 11-25-2003, 11:57 PM   #1
chromius
chromius's Avatar
Clutch is going I think....
okay, here is the problem....when the car is warmed up and I have been driving a while, when starting from a stop the car kinda shutters a little bit....does this mean the clutch is going? or the pressure plate is almost worn out? Also, at all times when in 1st or 2nd gear when I push the clutch pedal in while moving there is almost like a clunking noise (hard to explain) almost sounds like a rattle in the tranny or diff....I would really like some help with this. any suggestions would be helpfull. Thanks.
Old 11-26-2003, 01:09 AM   #2
crazyvadim
crazyvadim's Avatar
Send a message via AIM to crazyvadim
Do you get the clunking noise only on 1st into 2nd gear shifts??
crazyvadim is offline   Reply With Quote
Old 11-26-2003, 01:15 AM   #3
crazyvadim
crazyvadim's Avatar
Basically you gotta tell me if the sound occurs when the pedal is moved,when in neutral,when in gear or when the clutch pedal is held down to the floor?
Old 11-26-2003, 09:15 PM   #4
chromius
chromius's Avatar
When driving in first or second gear, under just normal driving conditions. I push the clutch pedal in and when the engine disengages from the driveline that is when I hear the clunking noise. Its hard to explain, but it almost seams like its worse when I am just driving slowly and coasting to a stop and the car is slowing down....then I clutch and its a clunk that sounds like its comming from the diff or tranny. I just had the trans mounts replaced, so could the diff mounts be shot as well? This problem could be a completely different one from the shudder when starting from a stop...I'm not sure. Hope this makes a little more sense. Thanks
Old 11-26-2003, 10:41 PM   #5
Jon@Bimmersport
Jon@Bimmersport's Avatar
it could be your subframe bushings...or maybe your clutch/gas co-ordination...
read the articles and tips on www.bmwe30.net and see...check the suspension page and transmission page
Old 11-26-2003, 11:57 PM   #6
chromius
chromius's Avatar
I don't think its my clutch/gas combination....it just started doing it recently, and I have tried varying my gas...no difference. (and I have been driving manual for quite a while... ) Thanks for the site though...I will check it out.
Is it a big deal to change subframe mounts?
Old 11-27-2003, 12:21 AM   #7
crazyvadim
crazyvadim's Avatar
its hard for me to tell you the problem from just a description,i would have to drive and most likely inspect and listen.From your description i think its a grabbing clutch,grabbing clutch produces a severe vibration or jerking motion when the vechile is accelerated from standstill,its usually caused by a clutch disc,pressure plate or maybe even a flywheel.My second guess would be a pilot bearing or a throw out bearing but like i said i would have to drive the car to determine the problem.
Old 11-27-2003, 08:22 PM   #8
Furious
BMW again.
Furious's Avatar
a shudder is a good first sign of the clutch going, mine started last thrusday, then the pressure plate blew one week later, of course it will varry from clutch to clutch but its a tell-tell sign
Old 11-29-2003, 08:29 AM   #9
chromius
chromius's Avatar
damn, thats what I was afraid of! I guess its about time I replaced it.
Thanks guys
Old 11-30-2003, 09:22 PM   #10
Furious
BMW again.
Furious's Avatar
if i were you, id buy the clutch kit , then ride this one out. thats what i did , however mine blew within week
Old 11-30-2003, 10:59 PM   #11
chromius
chromius's Avatar
Thats probably what I will do....I will have some fun with this one first!
