Old 11-24-2003, 04:13 PM   #1
djcontra
Gets Blown Daily
djcontra's Avatar
How do you install interior neons? Which 12v wires do I cut?
I'm actually installing interior LED lighting. I've begun to mount some custom made red led modules in my rear view mirror, footwells, door handles, glove box, etc, but what is the source of 12v power to connect it to? I'd really love for some of the leds to fade out with the roof lighting, and the footwell&door-handle leds to stay on while driving.
any help would be appreciated, thanks!
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 11-24-2003, 04:25 PM   #2
T-spec
T-spec's Avatar
Re: How do you install interior neons? Which 12v wires do I cut?
Takes way too long to explain, but if you come to feast tonight I'll explain everything you need to know. Later ,Big tommy T...
live fast, die quick, drive a bimmer
T-spec is offline   Reply With Quote
Old 11-24-2003, 04:35 PM   #3
djcontra
Gets Blown Daily
djcontra's Avatar
Re: Re: How do you install interior neons? Which 12v wires do I cut?
Ahh, give me a hint for now
I've got everything soldered to little breadboards, resistors and all, I just need to know where to connect the positive and negative
Mods
-Shortstack headers
-Vortech RRFPR
-Remus full catback
-SMT6 EMS (Untuned)
Old 11-24-2003, 04:42 PM   #4
T-spec
T-spec's Avatar
Whatever you want to fade out with the dome light, splice into the domelight wires, doesn't matter which one is +/-, if one way doesn't work, just reverse the polarities. As for the ones that will be on constantly, maybe wire in to a switched ignition circuit, or if you only want them on only at night maybe wire them into the headlight switch.
Old 11-24-2003, 04:50 PM   #5
djcontra
Gets Blown Daily
djcontra's Avatar
I was thinking of connecting the footwell and doorhandle leds to the dashboard dimmer dial....do you think that would work?
Mods
-Shortstack headers
-Vortech RRFPR
-Remus full catback
-SMT6 EMS (Untuned)
Old 11-24-2003, 04:56 PM   #6
T-spec
T-spec's Avatar
Yup, led's pull such little current that you can wire them right in to the circuit, no need for an extra relay for extra current loads, totally safe, go with it!
Old 11-24-2003, 04:57 PM   #7
WASABI
OG
That dimmer dial may not have not power and overheat. I'd wire the footwell/door handle ones to the parking light. You can only see them at night anyway and I don't really see the point in dimming them.
Old 11-24-2003, 06:13 PM   #8
djcontra
Gets Blown Daily
djcontra's Avatar
well I've tried the dimmer dial, and the foglight switch, but both don't work for lighting up my 12 led modules.
For now I've hard wired up the passenger side to the flashlight socket in the glovebox to see how everything will look. (I'll of course make it a clean install further down the road, but I need to look at some wiring schematics beforehand)
Mods
-Shortstack headers
-Vortech RRFPR
-Remus full catback
-SMT6 EMS (Untuned)
Old 11-24-2003, 07:07 PM   #9
niko_gt
niko_gt's Avatar
i wired some of my led's for some switches into an interior 12 volt lamp i think it was the ashtray light i hooked it up to, and when i use my dimmer to lower the intensity of the dashboard and the control buttons, my led's dim as well
just make sure u have the right resistors
niko_gt is offline   Reply With Quote
Old 11-24-2003, 08:47 PM   #10
T-spec
T-spec's Avatar
make sure the polarities are right, led's will only let current flow one way. If you try reversing the wires it should work, good luck
Old 11-24-2003, 09:26 PM   #11
djcontra
Gets Blown Daily
djcontra's Avatar
No worries, I tried switching polarities to see if the leds would light on the two switches, but no luck.
Niko, I'll check if my car has lights in the ashtray, and if it does, then I think I've found my solution!
Mods
-Shortstack headers
-Vortech RRFPR
-Remus full catback
-SMT6 EMS (Untuned)
Old 11-25-2003, 07:06 PM   #12
Justin e36
Justin e36's Avatar
Re: Re: Re: How do you install interior neons? Which 12v wires do I cut?
simply tap into any freakin 12v wires you want that stay on when u want. Not really tough to do... sounds ilke you got everyting else done... what color LED's did you use? ... I was going to go with blue.. but ended up going red... and have to say, it actually looks really good....
