Old 11-24-2003, 06:27 AM   #1
custom_bimmer
custom_bimmer's Avatar
wheel spacers
i am thinking about fender flairs and i need to know more about wheel spacers. are there any one else who makes them cheeper than h&r; they are going to be like $600 cdn for 30mm. would 30mm (1 inch about) be enough to fill fender flairs?
thanks alot,
keegan
custom_bimmer is offline   Reply With Quote
Old 11-24-2003, 05:50 PM   #2
aaron_silva
I would recommend getting wider wheels with a different offset to fill up fender flairs. IMHO.
Aaron Silva
1991 318iC
aaron_silva is offline   Reply With Quote
Old 11-24-2003, 06:57 PM   #3
thinair
moderationistismingly
thinair's Avatar
This would be the proper way to solve your problem.
You can get cheap spacers, lots of companies make them, but you usually end up with wheel vibration from them not being machined right, or properly balanced.
Old 11-24-2003, 07:06 PM   #4
takeshi
what about this, because I said the same thing as you did also.
http://www.maxbimmer.com/forums/show...threadid=24473
takeshi is offline   Reply With Quote
Old 11-24-2003, 09:47 PM   #5
jim s
try these guys, in the US
http://www.optauto.com/webstore/prod...t=410&last=410
I bought my 15mm spacers from them.
For the 1 inch H&R spacers (25mm), they go for $120 USD/pair.
With a full set, shipping and conversion, this should be less than
$600Cdn.
Good luck
HTH
jim s
jim s is offline   Reply With Quote
Old 11-24-2003, 10:02 PM   #6
SebSter
SebSter's Avatar
jim, if its 120 for a pair..wouldnt you only need two pairs? so how could it be 600?
SebSter is offline   Reply With Quote
Old 11-24-2003, 10:06 PM   #7
jim s
yes, <$600 Cdn
The $600 CDN reference was the ball park cost that the originator of the thread had mentioned.
Going with these guys should be less.
jim
Old 11-24-2003, 11:29 PM   #8
AMI Motorsports
Re: wheel spacers
thanks alot,
keegan
Hi Keegan,
We have spacers availble for your car:
30mm type B spacers - $201 CDN per pair.
Type B spacers fasten to your hub, then your wheel is bolted to the spacer with your stock bolts. These spacers are also hubcentric.
I hope the helps. Let me know if you have any questions.
Rob
Authorized distributor for FK Automotive, Rieger Tuning (all original parts, NO copies!!), Konigseder Tuning
Coilovers, Body Kits, Taillights & more...
AMI Motorsports is offline   Reply With Quote
