Old 11-23-2003, 10:12 PM   #1
johnoz
/OO=[][]=OO\
johnoz's Avatar
Myth or true
When you make a M50 conversion on an e30 I heard it has a lot of vibration this that issue.
Is this true?
johnoz is offline   Reply With Quote
Old 11-24-2003, 01:19 AM   #2
jeremy
not true
Old 11-24-2003, 01:22 AM   #3
johnoz
/OO=[][]=OO\
johnoz's Avatar
Hi jeremy.
When you did the conversion what 'needs' to be changed. The essentials not the options.
I mean yes the engine goes in, what else? tranny? diff? wiring harness? muffler?
TIA
Old 11-24-2003, 01:28 AM   #4
jeremy
basic list:
E30 M50 ENGINE CONV PARTS LIST
1. E30 88' radiator, i used the e36 unit with the lower mounts raised
2. E30 88' radiator over flow tank
3. E30 M20 fan, poss. w/clutch
4. E28 533i motor mounts w/ 5mm spacers or e28 m5 mounts with out spacers
5. E34 throttle cable
6. E21 brake booster w/ mod.shaft, to 15mm or 325IX/e32 735 without mod to the shaft
7. E34 M5 or 25mm brake master clyninder w/ additional brake line used for the 325ix boooster
or a e32 735i with the modded 320i booster
8. E30 325 trans Xmember
9. E28 m5 or two 320i trans mounts/ wich are cheaper
10. E30 M3 driveshaft or i used the front of the e36 mated to the rear of my e30 M3 have it rebalanced
11. E30 diff. w/ 3:25 ratio or E28 533i w/ 3:25 lsd
12. E30 318 ecu mount
13. E34 oil pan
14. E34 oil pickup
ect. ect.
15. E36 m3 exhaust manifold
16. M50 radiator hoses
17. E36 M3 Motronic
18. OBDI intake manifold
19. OBDI throttle body boot
20. E36 alloy mounting arms
21. OBDI wiring harness DO NOT BUY silver label “413” motronic, it has EWS (security),
it can only put into original chassis
22. the engine harness and the ECU are all E36 M3.
Old 11-24-2003, 01:29 AM   #5
jeremy
that list is for the m3 swap.....but you get the idea..
Old 11-24-2003, 01:33 AM   #6
johnoz
/OO=[][]=OO\
johnoz's Avatar
Amazing thanks
Old 11-24-2003, 01:35 AM   #7
jeremy
no prob....
Old 11-25-2003, 05:15 AM   #8
MarkD
MarkD's Avatar
Originally posted by jeremy
basic list:
I can supply you with a chip to work in an EWS system if required, as I figured out how to do this. Then you can use this "silver label" 413.
MarkD
