Old 11-20-2003, 08:41 PM   #1
wastedincome420
chip ?
When you do a "i" head swap onto a ETA 2.7 "e" motor can you still chip it??? If so do you get a chip for "e" or "i"
wastedincome420 is offline   Reply With Quote
Old 11-21-2003, 11:32 AM   #2
KC Ron Carter
the chip is determined by the ECU #
you decide to use.
The statement, "use the i head on an e" is a little bit of a problem.
Here is a link to check out.
http://www.bmwe30.net/cgi-bin/datacg...129&Section=03
You do not want to use an "i" head on an "e" engine, it will lower the comnpression ratio.
You do want to use the "i" cam and valve springs.
http://www.bmwe30.net/cgi-bin/datacg...001&Section=03
Later,
KC Ron Carter is offline   Reply With Quote
