Old 11-20-2003, 05:31 PM   #1
wastedincome420
Any tips on rear wheel bearings??
Well I have to replace a rear whell bearing on my car (87 325e)....
I was wondering if anybody has any tips or suggestion for me before I dive into this.
I know I seen a tool fro this in Bavarain atosport catalog but @ $250
wastedincome420 is offline   Reply With Quote
Old 11-20-2003, 05:40 PM   #2
BMW_M52_M20
Wheel bearings are something you can do yourself forsure......When mine went, I didn't have the space or equipment to work on my car so it was just eaisier to let my mechanic do it........
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 11-21-2003, 12:38 AM   #3
crazyvadim
crazyvadim's Avatar
Not a hard job,if you have some expierence anda service manual then it will go fine.Make sure you apply force to the correct bearing race or else bearing damage will occur if its jammed or incorrect race is pressed into the bearings.Also before installing new bearings,pack them with grease unless they are sealed already with grease.
Old 11-21-2003, 01:03 AM   #4
Jon@Bimmersport
Jon@Bimmersport's Avatar
too bad u dont live up here..bimmersport fixed mine for $200 CDN perside installed
Old 11-22-2003, 04:54 AM   #5
KC Ron Carter
rear bearings it is
Rear wheel bearings
On removal since it is bearing steel, with "googles" on strike the race with a cold chisel and it will shatter.
For installation BMW recommends three tools,
23 1 300
33 4 080
33 4 020
they pull the bearing in from the inner race.
hand tighten and lower car to floor for final torque, many have pulled them off the stands.
depending on size of nut:
22 mm is 129 to 155 ft lbs
27 mm is 173 to 192 ft lbs
Lug nuts are 66 to 81 ft lbs.
CV to drive flange are 42 to 46 ft lps.
Later,
KC Ron Carter is offline   Reply With Quote
Old 11-23-2003, 03:42 AM   #6
NickP
NickP's Avatar
Front wheel bearings are a piece of cake, the rears are a real challenge unless you have the special tools or the Snap On equivalent...
Old 11-26-2003, 10:56 AM   #7
///M3
just make sure u have the car supported in the air good or u will get hurt its not a hard job if u know what ur doing.
///M3 is offline   Reply With Quote
