Old 11-19-2003, 03:56 PM   #1
wastedincome420
Exclamation SI board
OK I'll make a long story short...
Since I didnt trust my own soldering skills on a printed circuit board I decided to allow a local TV reapir shop to do the task of soldering in new batteries on the SI board for my e30......
I would like to know how I can tell if it was all don properly and if theres any way to test it BEFORE I put the entire dash back together
wastedincome420 is offline   Reply With Quote
Old 11-19-2003, 04:03 PM   #2
Furious
BMW again.
Furious's Avatar
the only way to test it now is to put it in and see if things work properly.
Old 11-19-2003, 04:29 PM   #3
wastedincome420
Thanks......I sure hope it works and fix the overall problem (I had one of the lil' yellow LED's that would stay ON with the car off causing the car battery to die
Old 11-19-2003, 08:29 PM   #4
Furious
BMW again.
Furious's Avatar
ahh, how olds the battery?
Old 11-19-2003, 09:54 PM   #5
wastedincome420
I was unsure of the age on the battery that came with car (Exide) SO I went out and bought a NEW Napa battery.
But still that friggen LED stayed on after rthe car was shut down
So I figured the SI board batteries needed to be replaced....
After removal of the board I relized that it STILL had the original VARTA batteries ....
I replaced them with Radio shack ones.......I just got the board back from being soldered and should be able to put it back in the dash latter tonite when I get home.....I also figured I 'd have to "reset" the "Service lites"
Any comments???
Old 11-19-2003, 10:30 PM   #6
Furious
BMW again.
Furious's Avatar
did you find out what kinda draw the light was producing? i mean if a car at rest can support single flashing alarm light etc etc than you might have a bigger problem.
Old 11-20-2003, 02:29 AM   #7
wastedincome420
Well After getting it back together it "appears" to be fixed. NOW with the car off the light is no longer on....Then agian it now looks like the lil yellow light doesnt wrok at all
Also I WAS hopoing to have fixed the right side dash lights...After taking it apart and checking bulbs they still dont work either
Old 11-20-2003, 05:58 AM   #8
nzer
nzer's Avatar
I hope the batts he put in were rechargable..
To be honest does it really matter? Its a useless gimmic. Lose the batts and the SI lights. But you need the SI board for temp gauge and alternator charge.
I'd just forget about it.
BMWs Downunder
http://www.bimmersport.co.nz
nzer is offline   Reply With Quote
