Old 11-18-2003, 08:59 PM   #1
MatyBMW
MatyBMW's Avatar
Send a message via AIM to MatyBMW Send a message via Yahoo to MatyBMW
Any reason not to use spacers on stock wheels?
Is there any reason why I shouldn't use my 10mm hubcentric spacers on stock wheels for my E30?
Any adversities?
--MatyBMW
MatyBMW is offline   Reply With Quote
Old 11-18-2003, 10:05 PM   #2
fitz318is
Where did you get the spacers, Ive been looking for a pair.
If there is no contact and you use longer bolts I dont see why not.
fitz318is is offline   Reply With Quote
Old 11-18-2003, 10:27 PM   #3
Nope. Hmmm, my baskets would look pretty nice with some 8-10mm...
Old 11-18-2003, 11:18 PM   #4
MatyBMW
MatyBMW's Avatar
check www.amimotorsports.com
i'm happy with them, the company is out of barrie.
--MatyBMW
Old 11-18-2003, 11:51 PM   #5
windsor318is
Nitrous Junkie!
windsor318is's Avatar
mystikal i put my 25mm spacers in the rear just for laughs with my basket weaves, they looked amazing!!!!!!!!!!!!!!!!!
Old 11-18-2003, 11:53 PM   #6
Soldo
Soldo's Avatar
ya actually, there no downside really, it does give you better handling (wider wheel stance, even though its hardly noticeble!)
I think i'm gonna need spacers for my stock wheels if my coilover sleeves get in the way!
Keven Soldo
Old 11-19-2003, 12:01 AM   #7
BMW_M52_M20
How much were they??? Doesn't sound like a bad idea!
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 11-19-2003, 01:32 AM   #8
MatyBMW
MatyBMW's Avatar
$110 a pair
Remember you gotta buy the longer wheel bolts
they are like $2.85 x 16
--MatyBMW
Old 11-19-2003, 01:40 PM   #9
thinair
moderationistismingly
thinair's Avatar
Send a message via ICQ to thinair Send a message via MSN to thinair
Can't adding spacers (especially large ones) increase, or speed up the wear on the suspension components? Like bushings, balljoints and such.
Old 11-19-2003, 10:40 PM   #10
devarato
hey maty, wat kit do u have on ur car?
dubya dubya dubya dot bimmersport dot co dot nz
devarato is offline   Reply With Quote
Old 11-19-2003, 11:47 PM   #11
MatyBMW
MatyBMW's Avatar
Front: Eurostyle E36 M3
Side: Hartge
Rear: Reiger
Spoiler: Hartge
--MatyBMW
Old 11-20-2003, 04:57 AM   #12
takeshi
I always thought spacers was a yes or no thing, period. If you don't need them, don't put them on. If you get really cheesy spacers you'll get vibrations, since they might not sit dead in the middle.
takeshi is offline   Reply With Quote
Old 11-20-2003, 10:56 AM   #13
MatyBMW
MatyBMW's Avatar
But spacers make your car look better also by pushing the wheels out. Also, you don't get vibration with hubcentric spacers because the weight of the wheel lies on the hub of the spacer.
--MatyBMW
Old 11-24-2003, 10:36 PM   #14
AMI Motorsports
Very true, you will get little or no vibration with hubcentric spacers. They make your car look good, but they also improve slightly your handling by creating a wider wheel base. If you are looking to get 20mm or wide spacers, I would highly recommend using a Type B spacer, which fastens to your hub, then you use your stock wheel bolts to attach your wheels.
Just a piece of mind issue, instead of runing longer bolts. They work out to almost the same price.
I hope this shed some light on spacers
Authorized distributor for FK Automotive, Rieger Tuning (all original parts, NO copies!!), Konigseder Tuning
Coilovers, Body Kits, Taillights & more...
AMI Motorsports is offline   Reply With Quote
Old 11-24-2003, 11:18 PM   #15
Autotechnica
BMW Traitor
What brand are you guys buying? H&R sells them for about $450 for a full set. 10mm and 30mm.
You'll find that with spacers the car will try to follow the cracks and bumps in the road. They are barely noticeable. I don't understand the purpose of this as they will put more stress on your wheel bolts.
Nelson is right though, it will wear suspension components much faster as well.
How does this make your car handle better? The wheels aren't wider and the turning radius is unchanged unless you only use the spaces in the front or rear and not on both.
Bryan
'02 Mercedes C32 AMG 3.2L Supercharged @ 18psi - 341WHP/358lbs*ft TRQ (DynaPak) Eurocharged custom tune, ASP 178mm crank pulley + PSK, CM30 i/c pump, i/c iso kit, Magnecore wires, NW CAI, dual custom exhaust, H&R sway bars, H&R SS coilovers, KMAC camber kit, H&R spacers, Quaife ATB LSD, goodridge SS lines, Porterfield RS4 pads, AMG 18" rims, AEM UEGO wideband, Dashdaq datalogger, Kenwood Excelon DNX8120
