Old 11-14-2003, 09:14 PM   #1
AcidSnow
Boss of Bosses
AcidSnow's Avatar
tires
when to put my winter tires on, and I found the passenger side summer tire to be extremly worn from the inside??? all other tires are fine, what gives?
AcidSnow is offline   Reply With Quote
Old 11-14-2003, 09:18 PM   #2
moerom
moerom's Avatar
Might be a camber issue?
moerom is offline   Reply With Quote
Old 11-14-2003, 09:19 PM   #3
sadda///M
sadda///M's Avatar
alignment
sadda///M is offline   Reply With Quote
Old 11-14-2003, 09:25 PM   #4
AcidSnow
Boss of Bosses
AcidSnow's Avatar
aligment seems fine - car drives straight as an arrow
Old 11-14-2003, 09:25 PM   #5
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Holy god thats bad.
Stanceiseverything.com
Old 11-14-2003, 09:30 PM   #6
BMW_M52_M20
Wow, that looks like an alignment issue.......I don't know what else would cause that??? Man you must have had some fun rides in wet weather with those tires!!!
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 11-14-2003, 09:43 PM   #7
sadda///M
sadda///M's Avatar
how can you say it drives straight as an arrow with that tire on?
worn suspension/shocks? maybe but not likely
alignment geometry is focked up.. negative camber or toe-out. have it align.
Old 11-14-2003, 09:51 PM   #8
dtthiaga
Assuming the worn out side was the inside part of the rim, you’ve probably got a negative caster. Is your car lowered??? Lowering a car more than 1 inch usually introduces negative camber; this can vary though depending on the car.
It also could be a Toe in on that wheel.
Go for an alignment and have it checked out.
I’ve had negative camber on both front wheels and the car always drove straight. I’m not sure what would happen if it weren’t just one side; it might pull.
From the Net, here is some info about Camber, Caster, Toe
Camber
Camber is the tilt of the wheel in or out. Positive camber readings show the top of the wheel is tilted out, while negative readings show the top of the wheel is tilted in. Theoretically, you want the wheel to be at 0 degrees or straight up and down, and most vehicles are close to this, but suspension design or handling demands may require negative caster settings (Negative camber is usually used on performance cars).
Caster
Caster has no effect on tire wear. Caster is used for vehicle stability. Too much caster and the wheels can begin to shimmy like the front wheels on a grocery cart when you go too fast. To little caster and the wheels don't follow the path well. Caster is essentially how far forward or backwards the wheel is in the wheel well.
Toe
Toe refers to the in or out turn of the wheels from a straight-ahead position. Incorrect toe settings caused by wear or impacts can wear tires quickly. In the past, most vehicles would have "toe in"; the front of the wheels were turned slightly inwards. This gave good vehicle stability, and as vehicle speed increased, the tire resistance would cause the toe to change to the straight-ahead position
Old 11-14-2003, 10:32 PM   #9
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Originally posted by dtthiaga
[B]Assuming the worn out side was the inside part of the rim, you’ve probably got a negative caster. Is your car lowered??? Lowering a car more than 1 inch usually introduces negative camber; this can vary though depending on the car.
Caster
Camber.
Old 11-15-2003, 03:59 AM   #10
Originally posted by BMW BMXer
Holy god thats bad.
LMAO...I love your remarks.
Old 11-15-2003, 05:35 PM   #11
SpikedLemon
Send a message via ICQ to SpikedLemon
Rear Passenger wheel? As in the drive wheel?
That's what my buddy's Mustang's rear passenger wheel looks like.
- Rob.
2002 Chevrolet Cavalier 2.2 (Yellow)
2000 Honda CBR929RR (Yellow)
SpikedLemon is offline   Reply With Quote
