Old 11-12-2003, 09:19 PM   #1
Jon@Bimmersport
Jon@Bimmersport's Avatar
Internal E30 rust
i have rust in the engine compartment, and inside the trunk in the wells, as well as on the door pilar on the rear window next to the door part...im wondering, can this be de-rusted? lol...or is it like always going to be there and cause a problem?
Old 11-12-2003, 09:22 PM   #2
SpoolinS6
SpoolinS6's Avatar
it can be fixed but it will cost some cash !
2000 Jetta tdi Bagged
1995 Audi S6
HI BOOST
Old 11-12-2003, 09:24 PM   #3
Autotechnica
Little Chino
Those are the worst places to have rust. Depending on how bad it is you may or may not be able to fix it. Honestly, if I were to buy a used car and I found rust inside the trunk or in the engine compartment, I would avoid buying it completely.
Is it just surface rust or bubbling? If your not sure how bad it is, use some sand paper and lightly sand it, it shouldn't take long to see the metal surface if it's just surface rust. Since your car's black sand all the rust off and just touch it up with some "Tremclad" rust paint. It's black so it should cover up quite well.
I had a little rust on the inside of one of my fenders. I grinded it down and took out all the rust, touched it up with the Tremclad rust paint and the rust has never come back 2 years later.
Bry
Old 11-12-2003, 10:19 PM   #4
Jon@Bimmersport
wat grit paper? this is inside the trunk..not on the trunk openning but where the jack is...and in the hood its surface rust that is like peeling off lol
Old 11-12-2003, 11:26 PM   #5
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
I have rust under my trunk seals its not pretty.
Were you have it is worse.
I am of no help to u.
Stanceiseverything.com
Old 11-13-2003, 12:08 AM   #6
WASABI
OG
If it's just surface rust, then yeah, you should be able to sand it down to the metal and spray some good rust paint on it, then buy a can of that red Rust Check oil spray, and spray it afterwards. If the rust is all the way through, then there's nothing you can do but cut the panel that's rusted, and weld on a new piece.
Old 11-13-2003, 02:41 AM   #7
Jon@Bimmersport
wasabi..wanna help me with what u jus said? except the cutting one..lol
Old 11-13-2003, 03:15 AM   #8
ouch it seems like ur cars got rust in the worst places of all...
but do what everyone else said...
Old 11-13-2003, 04:03 AM   #9
BMW_M52_M20
Unfortunatly, those are spots where water get at over time which probably means it is not surface rust.....As mentioned those are crucial spots to have rust.....I can't remember who said it on here but "Once you get rust in those crucial spots, it is like cancer, never goes away."
Hey but try sanding it down then some bondo and you may have some luck.....
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 11-13-2003, 01:42 PM   #10
WASABI
OG
But I like cutting ... Just spray some black paint over it, what you can't see won't bother you.
Old 11-13-2003, 01:44 PM   #11
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
TIll his jack falls through and onto the road.
Old 11-13-2003, 05:42 PM   #12
WASABI
OG
Jack will be of no use anyway when all the jack points have rusted out.
Old 11-13-2003, 07:56 PM   #13
Jon@Bimmersport
ha ha ha mr. rustbucket civic..lol
the jack will still be of use so i can hit u on the head for those stupid comments hahaha...anyways, let me know if ur up for it.
