Welcome to!
Old 11-03-2003, 08:59 PM   #1
Your Nightmare
KIRASIR's Avatar
Exclamation Need a German translation.
Could someone who knows German translate this?
"Biete 3 Koni Stoßdämpfer Geld. Die Stoßdämpfer waren nie verbaut also Neu. Der Dritte Stoßdämpfer dient als Ersatz,weil er nicht mehr den richtigen Gasdruck hat. Die Dämpfer können in folgende Fahrzeuge verbaut werden : Bmw E36 320i,325i,325td,inkl.Coupe und M-Technik. Bj. von 9.91 - 5.92 Koni Nr. 8741-1248 L Koni Nr. 8741-1248 R beide Neu Koni Nr. 8741-1272 als Ersatz Diese Konis sind natürlich in der Härte einstellbar. "
Please do not provide translations from Google, AV, etc. I need to have an accurate translation and Google just doesn't do it.
Thank you
Old 11-03-2003, 09:58 PM   #2
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
Offer to 3 Koni shock absorber money. The shock absorbers never were obstructed a new. The third shock absorber serves as a substitute because he no more has the right gas pressure. The dampers can be obstructed in the following vehicles: Bmw E36 320i, 325i, 325td, incl. coupe and M technology. Construction year from 9.91 - 5.92 Koni No. 8741-1248 l Koni No. 8741-1248 R both new Koni No. 8741-1272 as a substitute this Konis are adjustable of course in the hardness. "
punnzzells is offline   Reply With Quote
Old 11-04-2003, 01:54 AM   #3
Posts: n/a
he want's a translator not alta-vista
