Old 11-02-2003, 07:48 PM   #1
KC Ron Carter
E24 with a MAF conversion before Turbo
Here is a MAF from Split Second
The controller is in the glove box, and is indexed to allow me to play with settings and get back to smooth running.
Here is the Ford 65mm MAF and it is made in JAPAN.
If this engine was shiny enough to reflect,
you would see me smiling while taking the pictures.
Cause I really like the output of the MAF.
Six hours, DIY, including the indicator and can switch back to AFM in 2 minutes, Two screw clamps on MAF, two quick electrical connectors and the OE connector is tie rapped back out of the way.
OE is
3430cc M30
Motronic
DME II
92x86, 8.0:1
185bhp/5400rpm
214lb.ft/4000rpm
I own a dyno so here is the output at the wheels.
HP loss in transmission and differential 25%
So 222 HP at shaft is the result.
I am using the J C. chip also, a 3.71 ratio, with 265 Getrag.
The sweet spot of the m30 is now at 2200rpm where it was at 2800rpm.
That is the point where the rumble of the exhaust resonates in frequency with the intake. On the unmodified it is only seen on the cold mornings when the fuel system adds a little more fuel and the cold air is giving it's all.
I really like it.
My Cartech RRFR installed and test in advance of the M102 12 psi turbo.
I hope to sneak up on a few Stangs and Meros on the Dyno.
My source:
http://www.bmpd.com/bmw/parts/catalog/engine_32.shtml
Later,
KC Ron Carter is offline   Reply With Quote
Old 11-04-2003, 10:23 PM   #2
Bigbore
wow. very sweet. how high do you have that cartech unit cranked up? Lots a Tq more... you are probably running a little rich (which is alright really) unless your program is compensating for it... hmm...
93 Saab
Bigbore is offline   Reply With Quote
Old 11-05-2003, 03:51 AM   #3
KC Ron Carter
Just testing the RRFPR
The RRFPR is installed for testing only at this point.
Lots more to bolt on.
KKK27 and M102 12 psi manifold and wastegate.
Here is a Metric Mechanic swirl ported turbo head.
This e24 is the tow mule for my mobile Dyno.
Later,
Old 11-05-2003, 03:57 AM   #4
SpoolinS6
SpoolinS6's Avatar
SHIT! this motor is nuts make a vid for us ! or atleast an audio clip !
2000 Jetta tdi Bagged
1995 Audi S6
HI BOOST
Old 11-09-2003, 01:59 AM   #5
KC Ron Carter
notice it is named tow mule
it is being built to tow my mobile dyno.
I will be happy to provide information when done.
Later,
