Old 10-30-2003, 11:53 PM   #1
Adriano
Who's your daddy now?
Adriano's Avatar
Send a message via MSN to Adriano
Wink Trade my M3 guage mph cluster for a km/h one
I have a guage cluster from a 97 M3 with about 25,000 miles on it that I need to trade for a cluster with the following requirments:
Must be in kilometers per hour
Does not have to be from an M3 but must be from a 6 cylinder
Looking for no more than 80,000 kms (prefer less than 50,000 kms but will take what I can get)
No scratches or major marks on lens
Please email me if you have one to alo@mnsi.net
Agent BMW trailer
Adriano is offline   Reply With Quote
Old 10-31-2003, 06:46 AM   #2
windsor318is
Nitrous Junkie!
windsor318is's Avatar
eh, you have enough posts to use an avatar know. (the little pic on the side)
Old 11-02-2003, 02:54 PM   #3
Jon@Bimmersport
Jon@Bimmersport's Avatar
why not get like white faced gauges but in KM? or silver body colour ones?
Authorized Ontario dealer for Active Autowerke|VF-Engineering|AFE|Bilstein Suspension|H&R Suspension|KW suspension|Brembo Brake Systems| Stoptech| - Call us for the best pricing
Old 11-03-2003, 01:17 AM   #4
windsor318is
Nitrous Junkie!
thats what i said but the odometer will still read im miles ( then his car wouldnt rev to 14,000 rpm
Old 11-07-2003, 04:55 AM   #5
BMWF1
Guest
Posts: n/a
LMAO, I thought it reved to around 19,000 RPM's he was smokin formula one cars last time i seen him
Old 11-07-2003, 11:24 AM   #6
Adriano
Adriano's Avatar
FUNNY!
Hey Al, thanks for the tip on the Avatar. Do you like mine?
My f***ing email doesn't work for some damn reason, you left your wheel lock at my shop.
Agent BMW trailer
Old 11-08-2003, 02:15 AM   #7
SickFinga
SickFinga's Avatar
If I'm correct you car adjust milage on your odometer to the milage on yout computer pretty easy.
Test 9
http://www.bmw-m.net/TechProc/test.htm
Old 11-08-2003, 06:44 PM   #8
windsor318is
Nitrous Junkie!
this one is better
YOU BACK ON SUNDAY????
Old 11-08-2003, 09:48 PM   #9
BMWF1
Guest
Posts: n/a
Originally posted by Adriano
FUNNY!
I try
Old 11-10-2003, 12:31 AM   #10
Adriano
Adriano's Avatar
Test 9
Again SickFinga, I must thank you for your help and your vast knowlege of our cars. The only question is that this link provides only the method of testing and viewing the info not changing it. How do you change this without getting the dealership involved?
Al. I'm back from London. I was REALLY debating to use this picture but when it is 100x100 my other one looks better.
Old 11-11-2003, 07:53 PM   #11
SickFinga
SickFinga's Avatar
It says if you hold the odometer button during test 9, it will overwrite incorrect milage to the real one.
The problem is if you have 200k on your odometer and 100k in your computer, which milage would it overwrite?
I dont know.
Old 12-28-2003, 09:50 PM   #12
Wilf
1. the test mode can report ROAD SPEED in KM, not distance travelled (ie. it does NOT reprogram the odometer).
2. the odometer CAN be reprogrammed to KM but has to be done with a speedometer programming tool (many $k). there are shops that will do it.
3. the problem on the M3 is the 8K (vs. 7K) tach - I've yet to find someone who has replacement faceplates to 8K (although some creative cut and paste with a KM speedo (leaving the original tach faceplate) might work)
4. any 6 cyl. E36 cluster will work however the redline on the tach won't be in the right place for the M3 (works fine on mine, you get used to burying the needle...)
Wilf - Toronto, Ontario.
'99 E36 M3 Convertible
'88 E30 325i Convertible
Wilf is offline   Reply With Quote
Old 12-29-2003, 03:02 AM   #13
Adriano
Adriano's Avatar
Thank you for that reply. I was dicking around with my cluster for a while now. I will be looking for a 6 cylinder cluster for replacment.
Agent BMW trailer
Old 01-01-2004, 08:33 PM   #14
Understated
7th Gear [SMG III] Member
Understated's Avatar
wait a minute..so does this mean it's possible to just remove the cluster and put in a new cluster that shows 'low kms' for ur car.
i wonder if losers do that when they sell their car(if it is possible..?)
Understated is offline   Reply With Quote
Old 01-02-2004, 02:45 AM   #15
Wilf
yup, nothing too high-tech on the E36 as long as the coding plug & cluster match - E46 also stores KM in the key transponder & a cluster reset is needed which results in the highest KM being displayed. (also what happens on E36 if the coding plug doesn't match)
