Old 10-29-2003, 12:16 AM   #1
thinair
moderationistismingly
thinair's Avatar
How to spend $600 on my car....
Well, I have roughly $600 burning a hole in my pocket that I've set aside for my car, what should I buy? Keeping in mind it's gotta be performance oriented...
My current plan is to get a a 3-gauge VDO setup to go below my OBC, (oil temp and pressure, and coolant temp), and an aluminum thermostat housing (to tap the coolant temp sensor into).
Anyone have any better ideas?
Don't bother mentioning driving schools, (I'm doing that in the spring regardless), or saving up for a turbo or something either.
Old 10-29-2003, 12:25 AM   #2
pbjaxson
Send a message via AIM to pbjaxson
Perhaps a Dinan engine chip or whatever..? I hear theyre pretty good...
pbjaxson is offline   Reply With Quote
Old 10-29-2003, 12:31 AM   #3
thinair
thinair's Avatar
I'm not a big Dinan fan, and this is $600 canadian dollars
Old 10-29-2003, 12:34 AM   #4
mkgino
M50 Manifold!!!!
mkgino is offline   Reply With Quote
Old 10-29-2003, 12:35 AM   #5
SpoolinS6
SpoolinS6's Avatar
hes getting that.........
id have to say maybe a high flow cat ??
or a header ??
2000 Jetta tdi Bagged
1995 Audi S6
HI BOOST
Old 10-29-2003, 12:37 AM   #6
app
fuzzy dice
Luke
92' 325i
app is offline   Reply With Quote
Old 10-29-2003, 12:40 AM   #7
thinair
thinair's Avatar
Originally posted by mkgino
M50 Manifold!!!!
I want to get the manifold when I either go for an OBD-1 conversion, or an M3 cams. Either choice will be accompanied by software and a bored throttle body.
I don't think I'd gain much with the manifold on it's own, in fact I'd lose some torque. Plus manifolds go for like $100-150.
or a header ??
Headers are big money, like $1000+US!!!
Plus just because this is a performance oriented mod doesn't mean it has to make my engine output more power (it can though )
Old 10-29-2003, 12:42 AM   #8
Jon@Bimmersport
Jon@Bimmersport's Avatar
xenon HID
or maybe save it for a roll cage? your only shy about 900 for a sweet roll cage
Old 10-29-2003, 12:42 AM   #9
WASABI
OG
Race seat? To keep you intact during those hard cornering. Kinda hard, since you've done quite a bit already.
Old 10-29-2003, 12:42 AM   #10
SpoolinS6
SpoolinS6's Avatar
id say save up some more and do the whole obd-1 convertion
u will gain good hp plus with software and a bored out throttle bodie ! go for it dudue !
1995 Audi S6
HI BOOST
Old 10-29-2003, 03:13 AM   #11
SickFinga
SickFinga's Avatar
save up for the cam kit if ou wanna stay NA
Old 10-29-2003, 03:18 AM   #12
mpower1226
mpower1226's Avatar
like you said, thinair, get those VDO gauges under bdc, but ask
T-spec to make you the housing out of carbon fiber. You wouldnt regret it.
Old 10-29-2003, 03:34 AM   #13
SebSter
SebSter's Avatar
carbon fiber hood? could reduce some weight...
SebSter is offline   Reply With Quote
Old 10-29-2003, 03:36 AM   #14
330DTM
Cinematographer
330DTM's Avatar
Re: How to spend $600 on my car....
I'd stay away from getting a chip for now since you mentioned you might be doing the cams and manifold later.
I'd just save the money for the more expensive mods which you plan on doing later, but if you really have to spend it i'd say the following depending on your use of car:
1. Stainless Steel Brake Lines
2. RE E36 Differential Cover
3. Fluidyne Alumnium Radiator
4. E36 Fuel Starvation Kits (but that's if you track your car often).
[https://secure1.nexternal.com/shared...&RowID=39&All=]
5. A Cool helmet, you'll need it for tracking in the future
Otherwise go for the UUC VDO Guages, they look cool and having an oil temp is helpful!!
-=Slow In Fast Out=-
Old 10-29-2003, 04:01 AM   #15
SickFinga
SickFinga's Avatar
i was thinking
is it possible to convert gas milage gauge to an oil gauge.
