Old 10-28-2003, 11:07 PM   #1
koncise
all you need is one mike
koncise's Avatar
Send a message via MSN to koncise
Battery draining... STILL.
Well I went to start my car today after not driving it for a few days (which is unusual for me), and it wouldnt start. I needed my dad to boost me.
I had this same problem last winter too (its fine in the summer)... someone said my alarm might be draining, I had it checked out - fine. Then I looked at my system. I even got it rewired better than it was. Capacitor display and both amps are shutting off. So that shouldnt be the problem either. I dont see any lights left on after arming/locking my car, so I have no idea what it could be.
Battery is less than a year old... Alternator was rebuilt this year also.
Anyone have any ideas?? I'm clueless...
koncise is offline   Reply With Quote
Old 10-28-2003, 11:55 PM   #2
SpoolinS6
SpoolinS6's Avatar
do u leave any lights on when u get out
are any lights on period when u turn of your car ??
that could be the problem something is draining it somehow ??
2000 Jetta tdi Bagged
1995 Audi S6
HI BOOST
Old 10-29-2003, 12:05 AM   #3
koncise
koncise's Avatar
The only lights that could stay on are the front corners/turn signals... the headlights go off with the car. And the car buzzes if I leave those on, so it doesnt happen.
The interior lights are on until I arm/lock the car.. then they fade out.
So I dunno
Old 10-29-2003, 12:38 AM   #4
SpoolinS6
SpoolinS6's Avatar
i dunno man
something must be draining it out
pull out the batterie and bring it back to where u bought it for them to test it ........
1995 Audi S6
HI BOOST
Old 10-29-2003, 12:48 AM   #5
crusher
OMGHI2U2
crusher's Avatar
EDIT: Looks like I found my problem. Battery needs replacing, it's never been replace since the car was born
Hey man! I have the same problem right now.. Car will not start it's doing the fast clicking/tack tack tack sound when you start the car and the lights will shutoff and turnoff when you start it. The only thing I did today was reset the oil service lights and found a fault code that says throttle position sensor using the Peake tool. But still, I did the reset and then even unplug the battery for an hour and same deal. All control works lights up the dash and the OBD and A/C is working fine. What could it be ? I checked the battery and its not bad.
Jeff
crusher is offline   Reply With Quote
Old 10-29-2003, 03:49 AM   #6
koncise
koncise's Avatar
Jeff
I was reading your other thread and spark plugs were brought up.... is that a possible cause of my problem? Cuz I think I actually do need new spark plugs.. I've never changed them since I got the car.. (not sure how often yer supposed to).
If I do get new spark plugs, which would u recommend? 92 325i auto
Old 10-29-2003, 04:14 AM   #7
WASABI
OG
Although your alternator was recently rebuilt, it may still be faulty. It has happened to me twice on my previous cars, the regulator was faulty. Check the voltage on the battery while the car is running, should be around 14.5 +/- .2 volts.
Old 10-29-2003, 05:34 AM   #8
blacknblue-e30
Just black, No blue
blacknblue-e30's Avatar
Send a message via MSN to blacknblue-e30
Hows the water level in the battery??
blacknblue-e30 is offline   Reply With Quote
Old 10-29-2003, 05:39 AM   #9
nzer
nzer's Avatar
I'm not sure about e36.. but the SI board in e30s has a factor in alternator charge.
BMWs Downunder
http://www.bimmersport.co.nz
nzer is offline   Reply With Quote
Old 10-30-2003, 04:04 AM   #10
Furious
BMW again.
Furious's Avatar
it could be your system. it could be killing your charging system. i got my alternator rebuilt bigger and stronger (more winds on the coil or something like that) ,, anyways my stereo system fried my alt and battery.
Old 11-01-2003, 08:51 PM   #11
koncise
koncise's Avatar
Whoops, forgot about my own thread
My capacitor displays 14.2... I think thats ok. It shouldnt be the battery anyway though, I had it checked out.
Do you guys think it would help if I turned my system down about 5 minutes before I got home? Maybe that way all the electrical crap will be fully charged and more likely to last a night or 2 in the colder weather..... what'd ya think? would it make a difference?
Old 11-02-2003, 09:44 PM   #12
snd84318i
snd84318i's Avatar
sh*****t samething to me today i went to PA to look for a gas tank and today i went to take off the tint on my driverside door and my car wouldnt start .new battery and before i bought the battery i started the car up with no problems idont know if i left something on , but the battery shouldnt just die like that right ?
snd84318i is offline   Reply With Quote
Old 11-02-2003, 10:17 PM   #13
jello_g
jello_g's Avatar
Sounds like you may have a short somewhere in your electrical system.
1988 BMW Dinan M3 2.6 Stage II
Gerald Lau's Facebook profile
jello_g is offline   Reply With Quote
Old 11-02-2003, 10:22 PM   #14
snd84318i
snd84318i's Avatar
yea but the thing is that i turned it on saturday and drove it fine . but today i went and nothing . my dad should be coming tonight to pick up my moms car so ill ask for a bost then i hope i left somthing on .
Old 11-05-2003, 12:07 PM   #15
Adriano
Who's your daddy now?
Adriano's Avatar
Send a message via MSN to Adriano
Can everyone that is having this problem please tell me if they have stiffening caps on their stereo systems? Sometimes (especially when using cheap or faulty caps), small amounts of current may actually ‘leak’ in the cap slowly draining power over time. It took me 3 months and 2 dry cell batteries to figure this out. I’m using 2 caps that I had abused and found them to draw almost 1 amp.
Agent BMW trailer
Adriano is offline   Reply With Quote
