Old 10-10-2003, 09:32 AM   #1
mentaleeill
which trans is better?
right now i have a 98 m3 5 speed mated to my m50 in my e30. i see alot of people using the e36 325 5 speed, and am wondering which is better. i know the m3 is a liitle heavier and also beefier but which has a better ratio for cruising on the highway? will my m3 240mm clutch fit in the 325 trans? i have a 325 trans laying around and have to pull the engine to drop in another chassis so it will be convenient to change the trans while its out. thanks.
mentaleeill is offline   Reply With Quote
Old 10-10-2003, 03:07 PM   #2
JazzM
6 speed euro
T.
Old 10-10-2003, 06:20 PM   #3
330DTM
Cinematographer
330DTM's Avatar
Re: which trans is better?
I assume that the OBD II M3's 96+ use a diff ratio of 3.23.
What type of driving do you normally do? Are you a drag racing, auto-xer, tracker, regular cruiser?
Do you find that your revs are too high at the speeds that you cruise at on the highway?
-=Slow In Fast Out=-
Old 10-10-2003, 09:20 PM   #4
mentaleeill
i travel a lot on the highway, do a lil drag, and am looking to get into autocross soon. i just want a quiet 5th with a good 1st gear takeoff.
Old 10-16-2003, 02:28 PM   #5
E30 Stu
Send a message via AIM to E30 Stu
The E36 325 gearbox (Getrag 250) has the same (minimal difference) ratios as the E36 M3 (ZF 310/320) gearbox. The M3 240mm clutch/plate/fly WILL fit in the G250 gearbox.
Go ahead and use the 325 gearbox you have, as it is lighter than the M3 'box and will work fine with a 240mm clutch.
Stuart McHenry
E30 Stu is offline   Reply With Quote
Old 10-17-2003, 01:17 AM   #6
Stu, you are the man.
