Old 10-17-2003, 12:20 PM   #46
E30 Stu
Send a message via AIM to E30 Stu
Pat--
Yes sorry I did forget to mention the bumped compression. I PM'd you about dyno information.
Stuart McHenry
E30 Stu is offline   Reply With Quote
Old 10-17-2003, 01:01 PM   #47
JazzM
Usually when you increase compression on a NA motor you'll get more hp... what compression is that one running? On street gas, then probably something lower than 11.5:1
Best Regards...
T.
Old 10-18-2003, 03:31 AM   #48
E30 Stu
We run 10.8 or so compression on street motors, 93oct. Keep in mind over time the compression raises, as carbon builds up on the piston tops, so after mileage that 10.8 moves to about 11:1.
Stuart McHenry
Old 10-18-2003, 12:48 PM   #49
JazzM
That's the same as the bekker's heads...
So you're saying that 11:1 compression with everything else stock = 250 hp?
T.
Old 10-20-2003, 06:22 PM   #50
97 Z3 2.8
That's pretty good. You certainly don't want to go much higher compression. These engines are built like freight trains, but avoiding predetonation is probably best.
Bill
1997 Z3 with N/A power adders....
97 Z3 2.8 is offline   Reply With Quote
Old 10-20-2003, 08:26 PM   #51
E30 Stu
I'm not saying that if anyone builds a motor like this with 11:1 that it will make 250whp. Ours did, with little to no tuning at all. My father has been building engines since before he could drive a car, so he has a bit of experience.
11:1 is pretty high for a street motor, 10.8-10.9 is how you want to build them.
Stuart McHenry
