Old 10-10-2003, 03:57 PM   #16
Peter1998
i saw a dyno of 210 rwhp from 328 with M50, M52Cams, cai and fan delete and software
which is around 245 crank?
stock M3 drivetrain loss is from 1.17 to 1.23.. where. 195-205 rwhp from 240 crank...
Peter1998 is offline   Reply With Quote
Old 10-10-2003, 04:16 PM   #17
JazzM
yup... sounds about right... except for the cams... should be S52, not M52....
T.
Old 10-15-2003, 07:16 PM   #18
97 Z3 2.8
Peter 1998- Your data sounds spot on. The dyno I saw was for a care set up the same without the M50 manifold. It was 197rwhp. You don't know what kind of software that guy was running do you? I've spoken to Peter @ superchips and he says he can custom tune it for me.
Bill
1997 Z3 with N/A power adders....
97 Z3 2.8 is offline   Reply With Quote
Old 10-15-2003, 08:24 PM   #19
mkgino
I think they were using the shark injector
mkgino is offline   Reply With Quote
Old 10-15-2003, 08:28 PM   #20
JazzM
JC has a specially tunned shark injector for the M3 cams and M50 manifold for use with the 2.8... Not the standard shark. However they don't sell it seperately and ony as part of THEIR cam kit...
goto www.sharked.com and look at the cam kits...
T.
Old 10-15-2003, 10:21 PM   #21
Peter1998
yah i got 196rwhp without the M50 Manifold as well.
Old 10-16-2003, 01:19 AM   #22
JazzM
Peter... what are you running for mods?
T.
Old 10-16-2003, 02:13 AM   #23
Peter1998
superchipped ECU, Intake, S52 Cams, Pulley, Fan delete, LWFlywheel, Catback Exhaust, 3.91 Diff for 196rwhp...
Now just did, M50 manifold and OBX Header.. gonna go dyno again someday..
Old 10-16-2003, 02:25 AM   #24
JazzM
what's the stock 2.8 rwhp? 165 (based on 189 and 18% loss)
T.
Old 10-16-2003, 02:47 AM   #25
Peter1998
i am not sure.. but people with ECU CAI and Catback, usually get 180-185...... M52 328 engine is undergraded
Old 10-16-2003, 03:43 AM   #26
JazzM
Peter, how do you like the 3.91 diff? are you automatic or manual? 5 spd? I'm thinking about the 3.38 or the 3.46...
T.
Old 10-16-2003, 05:20 AM   #27
Peter1998
mine is 5 spd hehe.. 3.91 is damn good on track, but on highway... it is little pain.......... keep 4k rpm with 120km .... max i can go is 220km at 7500 rpm.... . i dont want to go more coz i think my valve spring cant handle more..
well i think 3.46 will work the best on 5 speed
Old 10-16-2003, 02:23 PM   #28
E30 Stu
Send a message via AIM to E30 Stu
Misinformation at its finest...
Pat--Head work yields 1-2hp with cams? No headwork can be done on an M50/S50 engine? Think again man. The M50/S50/M52/S52's we build get extensive headwork. We do heavy porting, valve reshaping, guide shaping, relief grinding, valve pocket work and 5-angle race valve job. Our 3.2L OBD-1 car puts 250 to the rear wheels on stock camshafts. Headwork does wonders if it is done correctly.
Stuart McHenry
E30 Stu is offline   Reply With Quote
Old 10-16-2003, 02:42 PM   #29
JazzM
E30Stu... what ECU tunning do you do for your head work?
T.
T.
Old 10-16-2003, 06:56 PM   #30
97 Z3 2.8
JazzM- Peter is the guy Chris and I did the M50 swap for. Chris spent a day and a half putting those OBX headers on there for him. He had to custom fabricate holes in the header for the secondary air pump system. Apparantly quite a job.
E30Stu- Sounds like quite a bit of work. Who did the CNC work for you?
Bill
