Old 10-02-2003, 09:18 PM   #1
low_bmw
Location: "ANYWHERE WHERE THE PAVEMENT IS SMOOTH AND THERE IS NO SPEEDBUMPS" Toronto (Etobicoke)
car is hesitating
Anyone have had this problem?
I start my car and I start driving and it hesitates very bad for about a good 10 seconds then the car runs fine, until I start it up again and it does the same thing? Has this happened to anyone? If so what was the problem?
low_bmw is offline   Reply With Quote
Old 10-02-2003, 11:10 PM   #2
AndreNY
AndreNY's Avatar
Re: car is hesitating
maybe cause the car is to low, the cold weather freezes the cut springs and untill it worms up the car runs like shit
Do you have a check engine on, if so make sure you get it check out, it could easily be a O2 SEnsor, but its very hard to tell on the newer cars what it is untill the computer say's it
Down and Out that's the way to go...
AndreNY is offline   Reply With Quote
Old 10-03-2003, 12:08 AM   #3
Soldo
Soldo's Avatar
Well if this is a recent problem it just might be because of the cold weather. I'm not sure what exactly you mean, but you just have to wait for the car to warm up?!
Keven Soldo
Old 10-03-2003, 12:39 AM   #4
e36crazy
Just curious, How much does an O2 sensor go for?
e36crazy is offline   Reply With Quote
Old 10-03-2003, 02:01 AM   #5
JazzM
either that or pour some injector cleaner into the fuel tank next time you're @ a gas station...
T.
Old 10-03-2003, 08:01 PM   #6
low_bmw
What do you guys think it is. I thought fuel filter, ignition wires or O2 sensor. Has anyone had this problem?
GO LOW OR STAY HOME...GO LOW OR STAY HOME...GO LOW OR STAY HOME...
MY RIDES:
1994 318 CABRIO (SOLD)
1991 CIVIC ZC (SOLD)
1999 CIVIC LX (SOLD)
1999 E36 M3 CABRIO (SOLD)
1998 INTEGRA GS (STOLEN IN 4 DAYS)
1999 ACURA EL PREMIUM (SOLD)
2002 330CI M PACKAGE
Old 10-05-2003, 05:04 PM   #7
Autotechnica
BMW Traitor
Well if you just started the car and the engine's cold, don't expect it to run perfect. Your not suppose to rev the shit out of it at this point anyways. You should only worry if the car reaches normal engine temp. and there is still hesistation problems.
Bry
'02 Mercedes C32 AMG 3.2L Supercharged @ 18psi - 341WHP/358lbs*ft TRQ (DynaPak) Eurocharged custom tune, ASP 178mm crank pulley + PSK, CM30 i/c pump, i/c iso kit, Magnecore wires, NW CAI, dual custom exhaust, H&R sway bars, H&R SS coilovers, KMAC camber kit, H&R spacers, Quaife ATB LSD, goodridge SS lines, Porterfield RS4 pads, AMG 18" rims, AEM UEGO wideband, Dashdaq datalogger, Kenwood Excelon DNX8120
Old 10-05-2003, 05:43 PM   #8
low_bmw
No, I let i run for 2-3 minutes. Then when I start driving the first 10-15 seconds it hesitates bad. After it runs smooth until I start it again and it does the same.
MY RIDES:
Old 10-05-2003, 05:52 PM   #9
Soldo
Soldo's Avatar
When you say it happens every time you start up again, is that EVERY TIME, or just every COLD start?!
Make sure at least the ENGINE TEMP is at the middle of the guage then see how she runs!
Keven Soldo
Old 10-05-2003, 05:55 PM   #10
low_bmw
Every time cold or hot. Its only when I start driving 1st, 2nd and sometimes 3rd gear and then it runs fine until I start it again. When it hesitates in gear I push in the clutch and it revs from like 400rpm to 1200rpm up and down.
MY RIDES:
Old 10-05-2003, 06:20 PM   #11
Lennon
will kill ALL postwhores
Lennon's Avatar
Send a message via ICQ to Lennon Send a message via MSN to Lennon
'bout $150 - $200 for a O2 sensor isn't it?
Lennon is offline   Reply With Quote
Old 10-08-2003, 03:59 PM   #12
AcidSnow
Boss of Bosses
AcidSnow's Avatar
I got the same problem, I think I'm gonna try and change the fuel filter
AcidSnow is offline   Reply With Quote
Old 10-08-2003, 07:25 PM   #13
low_bmw
If you have the same problem. It's the mass air sensor. Does anyone have an idea of what it costs?
Old 10-08-2003, 11:47 PM   #14
Bliss
Administrator
I had the same problem with my E36. I must have brought it into bmw about 10 times with the same problem. They finally changed the idle control valve. They ended up changing my control valve about 6 times in the 3 years i had the car for. Not sure if that's the problem in your case though.
For maxbimmer decals, and t-shirts, email info@maxbimmer.com
Old 10-09-2003, 12:33 AM   #15
low_bmw
How much does it cost for the IDLE CONTROL VALVE and how much labour. And how much does a MASS AIR SENSOR cost if anyone knows. thanx
