Old 09-25-2003, 12:05 AM   #1
bE30mM50w
ShadowLine Trim??
i blacked out my trim a while ago but now since im re-painting the car, im going to spray the trim with flat black. how can i remove the outer part or the window trim(the part closest to the body)? also, once i remove it, can i put it back on or do i have to buy new pieces?
bE30mM50w is offline   Reply With Quote
Old 09-25-2003, 01:12 AM   #2
Boris The Blade
you should be able to pull it off with alittle finesse, try not to kink it. also, before you paint it black, spray them with Etching Primer. It help the black stick better to the metal, its snot green so dont get freaked out. oh, use satin black, not flat. looks alot better.
Boris The Blade is offline   Reply With Quote
Old 09-25-2003, 01:41 AM   #3
bE30mM50w
i was going to use the factory 2001 BMW Flat Black. the stuff for the bumpers/side mouldings. should i not?
