Old 09-21-2003, 06:37 PM   #1
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
Send a message via ICQ to HooliGaN* Send a message via MSN to HooliGaN*
foglights in 318is
ive been planning for a while to install some fogs into my car because of the 1337ness factor but i just have two questions what is involved in doing this and how much will it cost?
im sure some u guys have done this just give me some of your feedback after the whole situation.
Julian
HooliGaN* is offline   Reply With Quote
Old 09-22-2003, 01:58 PM   #2
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
bumpz0r comon guys i know someone can help me
Old 09-22-2003, 06:21 PM   #3
Miguel
...Delt Smash
Miguel's Avatar
PM Bimmersport, he can help you find them and install them for you.
Old 09-25-2003, 02:24 AM   #4
Adriano
Who's your daddy now?
Adriano's Avatar
Send a message via MSN to Adriano
Wireing harness is already there, no need for wiring. Just pop out the covers, install the fogs, plug em in to the harness that is tied up and has covers on them. You will need to buy a fog light switch. PM me when you get a price because I have one extra. Pop out the cover under your light switch and plug in the fog switch. DONE! Install time 15 minutes.
Agent BMW trailer
Adriano is offline   Reply With Quote
Old 09-25-2003, 02:51 AM   #5
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
u serious its that easy wow
haha
im so getting foglights now
are u going to bimmer cruise adriano
cause maybe i can buy the switch off u then
Julian
Old 09-25-2003, 05:02 PM   #6
WASABI
OG
You might have to buy the brackets too. Not sure if they are already there.
Old 09-25-2003, 05:21 PM   #7
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
ok thanx for the heads up man
Julian
Old 09-26-2003, 12:38 PM   #8
Adriano
Adriano's Avatar
haha
Julian
I wish I could. Sent you a PM
Agent BMW trailer
Old 10-12-2003, 01:35 AM   #9
BMWF1
Guest
Posts: n/a
Correction, 318i has wiring harness inside, 318is has nothing, I looked for about 2 hours and nothing, I went lookin on other forums and found people saying the same thing, NO WIRING HARNESS!!, here is what you need, go to the deal and ask for part numbers:
61 12 9 410 398
61 31 1 388 364
61 31 1 387 054(switch inside the car)
you will also need a 5A Fuse, costs pennies.
search google for 318is fog or wiring and you'll find the step by step, with pics its not to difficult to wire it up if you have the books, but its defently not 15min. To install fogs on 318is the price just went up around 150Can. Sorry bout ur luck but i'm in the same boat.
Old 10-12-2003, 03:22 AM   #10
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
i found the wiring harness for the actual lights
am i gonna b missing the harness for the switch
Julian
Old 10-13-2003, 12:30 AM   #11
BMWF1
Guest
Posts: n/a
Bro, you ain't listening there is NO wiring harness for the Fogs, sure you'll find A wiring harness, ask Adriano I spent 3 hours today trying to wrip the fog light harness out of his roll-over, to put it in my 318is, get a quote for those part numbers and that is your only solution. Unless u want to drive down to windsor and spend a few days taking it out of the roll over, fuk that thing is a bitch
Old 10-14-2003, 01:17 PM   #12
Adriano
Adriano's Avatar
Oh common, I thaught that you were having a good time!
Looked kinda fun to me!
Agent BMW trailer
Old 10-14-2003, 01:47 PM   #13
I had a shop put in my strobes for me, which is the exact same procedure as fogs. They charged me $40. The owner has an E36 318is, so he knows the cars. PM me for more info.
Old 10-15-2003, 06:59 PM   #14
Adriano
Adriano's Avatar
Actually, it is not the same procedure as the fogs. It very easy to just run some wires and throw in a toggle switch but I think that the scope of this thread is to use the OEM factory harnesses and switch. Strobes use very little power and can be run of 24 gu wire. Don't use any less than 16 gu wire or use a relay if you arn't going the OEM rout.
Agent BMW trailer
Old 10-16-2003, 12:42 PM   #15
Okay, well it is thicker wiring. I do not see how this makes it much more difficult. Mount-Wire-Fuse-Wire-Switch. Very simple.
