Old 09-13-2003, 11:05 PM   #1
RaIIi
Sticky throttle
My throttle isnt smooth seems to stick about halfway through the movement of the peddle. Its an older car, thats been sitting for a while, which is the reason the throttle sticks ....
What can I do to free it up, and get it working smooth again?
Lube the peddle, throttle body, throttle lever? with what lube?
RaIIi is offline   Reply With Quote
Old 09-14-2003, 03:30 PM   #2
RaIIi
WD-40'd all the throttle linkage, still stiff .... should I just go ahead and replace the cable, etc??
Any help is needed thanks guys
Old 09-14-2003, 08:04 PM   #3
Grimis
i have somewhat the same problem
i'm getting my throttle body cleaned today cause my butterfly flap is sticking (stays open) when i boot it in 1st and only 1st......i thought it was the pedal before but the pedal pushes back up all the way.....so i came to the conclusion that it has to be the butterfly flap.........get throttle body cleaner from crappy tire, it's in a white can i believe
Grimis is offline   Reply With Quote
Old 09-14-2003, 08:53 PM   #4
RaIIi
Yea I have some of that laying around was going to try that next, probably just some crap buildup somewhere sticking
Thnx
