Old 09-12-2003, 06:29 PM   #1
Autotechnica
Little Chino
relatively new M3 clutch
Looking for just the clutch, I've got the flywheel and pressure plate.
It's for a 1995 3.0L M3.
Thanks,
Bry
Old 09-12-2003, 07:15 PM   #2
KIRASIR
Your Nightmare
KIRASIR's Avatar
Where did you get the flywheel from? Charlie? And how much was it?
SL
Old 09-12-2003, 08:27 PM   #3
Autotechnica
Little Chino
Hey Serge,
Got it from Nick P here on Max. $150 for a used clutch, flywheel and pressure plate. The clutch is quite worn so I need a new one.
Does this thing just bolt on the 318 or do I need to modify something?
I'm going to clean it up a bit
Thanks,
Bry
File Type: jpg sachs \'95 3.0l m3 flywheel, clutch, pressure plate.jpg (88.2 KB, 46 views)
Old 09-12-2003, 10:09 PM   #4
KIRASIR
Your Nightmare
KIRASIR's Avatar
It's pretty much a direct bolt-on. You would need new bolts of course. You might also need a new clutch fork as well.(I can't remember for sure. Charlie should know.) I'll probably be swapping mine sometime during the winter/spring too.
SL
Originally posted by Autotechnica
Hey Serge,
Thanks,
Bry
Old 09-13-2003, 12:01 AM   #5
Jon@Bimmersport
Jon@Bimmersport's Avatar
what is the advantage of using M3 flywheel/clutch on a 318 compared to aftermarket?
Old 09-13-2003, 12:37 AM   #6
Soldo
Soldo's Avatar
if you need the SOCKET to take out the tranny, lemme know, if you plan on doin it yourself, i had a problem cause BMW uses a SPECIAL tool, that you can't find anywhere, so i made a CUSTOM ONE, just lemme know
Keven Soldo
Old 09-13-2003, 01:20 AM   #7
Autotechnica
Little Chino
Jon,
It has a larger surface area and can handle more power. It's also much grippier since I find non M3 clutches tend to slip. Since I have to replace the clutch anyways, might as well upgrade. There is no downside because the M3 flywheel is about the same weight as the stock 318 one.
Kevin,
I think I'm going to get someone else to install this for me. I would love to screw around with it and see if I can do it myself, but don't have as much time now that school started. Thanks for the offer anyways
Bry
Old 09-13-2003, 01:23 AM   #8
Autotechnica
Little Chino
Serge,
Thanks for the info. I'll probably get charlie to install it for me if he's willing
I see that the Sachs M3 Sports clutch plate is around $500US! Any idea how much a stock SACHS M3 clutch plate is? Sport is more expensive correct? I see the 318 clutch plate is only $90US! What a difference.
Bry
Old 09-13-2003, 03:31 AM   #9
KIRASIR
Your Nightmare
KIRASIR's Avatar
95 M3 Clutch kit is only 240US, pressure plate is 150 from
bimmerparts.com. There is absolutely no point of getting a sports M3 clutch for your car. It will be just a waste of money.
SL
Serge,
Bry
