Old 08-25-2003, 11:56 PM   #1
tiestoE36
tiestoE36's Avatar
thud in the rear end
i have been hearing a thud in the rear end of my car when in put it in to gear for the past few months, and it has been drivong me crazy. anyways finally today i took it to my mechanic and he changed the transmission oil, no it is running allot smother. the thud has gonr away, for the time being.
i just wanted to report because i have ask ppl here before if the had this problem.
tiestoE36 is offline   Reply With Quote
Old 08-26-2003, 03:56 AM   #2
Mitch555
Retired MaXmember!
Mitch555's Avatar
Maybe your tranny is just jumping into gear really hard. Hopefully your problem is solved!
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
Mitch555 is offline   Reply With Quote
Old 08-27-2003, 12:08 AM   #3
Soldo
Soldo's Avatar
i have this same problem, but with me it only happens when the car is cold, like when i first turn it on for the day, after it warms up its all SUNSHINE!
Keven Soldo
Old 08-27-2003, 04:36 AM   #4
crusher
OMGHI2U2
crusher's Avatar
Maybe your rear shock mounts are kapish?
2013 Ford Focus SE
2011 Lincoln MKT
2003 Escalade 8 Seater of Fun - 251k and still running
Sold/Traded-in
2006 M5
2003 M3
2003 Civic Si
2000 M Coupe
1999 M3
1999 323i
crusher is offline   Reply With Quote
Old 08-27-2003, 06:03 AM   #5
tiestoE36
tiestoE36's Avatar
well this is a few days later, i still have the same problem, every time i put it in to first, i hear the thud. still need to find out the problem.
Old 08-27-2003, 06:07 AM   #6
jeremy
do you hear a rattling on acceleration or decel ?
Old 08-27-2003, 12:50 PM   #7
SpudBoy
Couped up
SpudBoy's Avatar
Send a message via ICQ to SpudBoy
I had the same sound in my old e36 328i. It was just barely noticable. I didn't really consider it a problem since it never got any worse during the two years I owned the car. As I recall from roadfly it was a fairly common occurence but I don't know the fix.
Lets just hope crusher's not right
SpudBoy
'99 M Coupe - Imola/Imola
Signature Pictures by Alezone
original BMW parts
To mod or not to mod? That is the question
SpudBoy is offline   Reply With Quote
Old 08-27-2003, 01:24 PM   #8
crusher
OMGHI2U2
crusher's Avatar
I hope so, but some older e36 have their RMS go bad after years of driving. I had mine replaced a couple of months ago with the JT Design RSM and i'm pretty happy with it.
Anyways, I see you mentioned that it went away when your mechanic put in new transmission oil, now i'm confused usually even if you change oils etc the thumping sound should still be there if the RMS went bad.
Also, get your car lifted and check the underneat. Usually you can find some loose parts that might be causing it.
Jeff
2013 Ford Focus SE
2011 Lincoln MKT
Sold/Traded-in
2006 M5
2003 M3
2003 Civic Si
2000 M Coupe
1999 M3
1999 323i
Old 08-28-2003, 03:06 AM   #9
Autotechnica
Little Chino
It's could be your rear sub-frame (diff carrier mounts) are cracked or about to break off. The thud you described is usually the sound of the differential hitting against the chassis. But there is no way to tell unless I can actually hear/feel the thud. Almost anything can cause a thud, so get your mechanic to check it out, a good mechanic.
This problem is usually caused by improper shifting techniques, total abuse of the car or accidents.
Bry
Old 08-28-2003, 04:59 PM   #10
tiestoE36
tiestoE36's Avatar
Bry
my mechanic checked that all out, but its nothing like the rear subframe.
as i put it in to first gear, with the clutch full depressed, i hear the thud.
it is an internal thing. it has been doing it on and off since i got the car.
