08-23-2003, 04:30 AM
#1
Car: 02 330 ci
MY 330 ci
i was just wondering wat would be the best way to race with my car the engine is stock and i turn off traction control which makes a huge difference in my launch but i still am not satisfied
please dont post any stupid comments about i cant drive unless your a shumacher
i find when i launch with traction off then turn it on after 1st gear i get better times
is this bad
wat should i rev to when i lauch
please help
08-23-2003, 04:37 AM
#2
Car: MK4 Jetta TDI
IMO, just FUK the Traction, can't help much, i mean when it cuts power to the engine it does it worse then your foot would do!
08-23-2003, 04:41 AM
#3
Car: 02 330 ci
you think but i am satisfied with it after first just after launch i feel a slight pause kinda
could this be some restriction or a limited slip am i revving to high or to low to launch
2002 330ci - premium/sports/metallic paint/aerodynamics kit packages
Pirelli tires w/ ,18inch custom model 71 bmw rims,ACS pedal set inc dead footrest ,ACS shifter and Short shifter kit ,ACS E brake,ACS front badge, Bilstein pss 9 coilover kit , Kamei eyelids, Tint, Viper Pager Alarm , Custom intake, Red Calipers, shaved trunk and door keyholes,oem clears all around, piaa bulbs all around and interior.
08-23-2003, 04:43 AM
#4
Fuel Efficient 318 Member
Car: 318ti
The first thing an real automotive enthusiast does before putting it in gear, is pressing the traction control off button.
08-23-2003, 04:48 AM
#5
Car: 02 330 ci
ok i dont no if ur implying that im not a real enthusiast or watever but i do turn it off
as i posted in the very first post
08-23-2003, 01:28 PM
#6
OMGHI2U2
Car: 03' Lade & 03' M3
turn off a/c and then ACS+T or DSC for u.. I feel that the a/c eats too much when doing a launch
2006 M5 SMG III | Dinan Stage 1 Software
2003 Escalade 8 Seater of Fun - 232k and still running
Sold/Traded-in
2003 M3
2000 M Coupe
1999 M3
1999 323i
08-23-2003, 01:46 PM
#7
Cinematographer
Car: LSB - ///M3
Just leave traction control and DSC off if you're doing launches.
Also when you launch, do it at the right revs because if you don't, you're just going to bog off the launch and it's pretty easy to tell if you bogged or not.
I've never driven a 330 before so I don't know the right revs, however you just gotta play around till you find the sweet spot.
Also too much wheelspin will result in a crappy start. Again you may want to experiment but if you launch try dumping it and then try it again but slipping it just enough that you get that perfect launch.
-=Slow In Fast Out=-
08-24-2003, 05:42 AM
#8
Car: 02 330 ci
all i turned off was my little asc button beside my shifter is there another buttom to turn off or is that it
does anyone know wat revs i should stick around to find my best launch
08-24-2003, 05:48 AM
#9
Car: MK4 Jetta TDI
well with the revs, its basically trial and error, USUALLY somehwere around 3-4000 RPM, i would assume would be a good launch, but one thing to improve the launch, don't just DUMP the clutch when you launhc, you gotta sorta play with it, like go to the point where the clutch is about to grab, then sorta release it SLOWLY and once you start to sorta FEEL it griping, then release and give FULL throttle!
08-24-2003, 06:09 AM
#10
Car: 02 330 ci
thanks solda i appreciate that
my car is much different from all the my other cars
i no my car has more potential and im just trying to find out without the really big trial and error period so i dont fuk anything up
08-24-2003, 10:25 AM
#11
Gets Blown Daily
Car: 1994 333HP Supercharged Project E36, 1996 Hummer H1
Just watch out that you don't rev too much and burn out your clutch (like I've been doing accidentally  )
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
