08-18-2003, 12:02 AM
#1
///M Testing Engineer
Car: E30 325i 1990
engine problems(stop by itself)
here's my problem
I started the engine and then eared(sp?) a noise(like something blowing up ) , but not a loud one. and white smoke was coming out of the front left side. engine did not stop. its just when i saw the smoke that i turned it off.
When I started it the second time, the engine had a hard time running(like wrong timing) and stopped by itself...
I tought the problem was the timing chain, so i checked it out, but it seems in good condition.
Anyone have a clue on what it could be(head gasket)?
ps: everything that's in front of the engine; belts, covers, radiator, fan... have been removed. So I can't check if there's a fault code, right?
08-18-2003, 02:07 AM
#2
AKA:e36=m3square
Car: 93 325is
take out he spark plugs and check the colour of each one, then colour of the oil and smell
08-18-2003, 01:57 PM
#3
Car: E30 325i 1990
hi,
I did check the spark plugs, they were in good condition. Did not check the oil thought. I will.
but I don't think this is the prob, because I changed the oil(full synthetic 5W50) a few days before storing it for the winter. well I'll check it anyway.
08-19-2003, 12:15 AM
#4
AKA:e36=m3square
Car: 93 325is
oh ok, don't forget to smell it
then try to turn the engine by hand, see if it can turn
08-19-2003, 02:40 AM
#5
BMW again.
Car: 1994 325is
you can still run your car without any belts, (however its very important that you do NOT im just trying to prove a point), you can still check for a fault code.
also what did you mean by "left side" (passenger or driver side)
lastly how long has it been in storage?
08-19-2003, 10:16 PM
#6
Car: E30 325i 1990
m3square: which smell am i searching for?
also I can make the engine turn using the crankshaft...
furious325is: by left side i meant driver side and my car was stored for 6 months, then I took it out for short rides and then the problem occured.
Now you said I could check for fault codes if the belts are off, but can I if EVERYTHING listed is? I don't want to get all codes possible or oil everywhere on the garage's floor
another question:
-Is it normal to have both, exhaust & intake, valves opened at the same time on 2 cyl (1 & 4) and the oposite(all closed) on the 2 & 3 cyl? I know that cylindres work in pair, but can't figure out how intake and exhaust valves can be opened at the same time.
sorry if this sound stupid but i'm new to mechanic, since its my first car
thanks for your help guys, i'm going to check this at last this week-end so if anyone else has a clue.... it's welcome
08-19-2003, 10:57 PM
#7
BMW again.
Car: 1994 325is
how are you checking your fault codes? are you using a modec? or the traditional homemade way? if your using a modec, youll get all running codes, but i think everything you listed will not give you a code that i can think of. except maybe your voltage (alternator) and a possiblility of a coolant issue
08-20-2003, 03:24 PM
#8
Car: E30 325i 1990
i'll use the homemade way, costs less
08-25-2003, 03:50 AM
#9
Car: E30 325i 1990
heres a little update:
I've worked on my car this weekend and the oil smell is okay, also checked out the color. it was ok too
There were no fault codes
going to sleep, cya
08-25-2003, 05:22 AM
#10
Car: E30 318is Arctic Rot
tuned318 After storing my car for just 2 months it really didn't want to start again.. I cranked it forever untill it started.. then It was only running on 3 cylinders untill it warmed up. I also had a lot of white smoke coming from the tail pipe and a loud clicking noise that lasted 30 min. I hope it doesn't do this to me again next spring because i just rebuilt the motor over the winter.
Unless you blew the head gasket the last time you drove it, or something has siezed in the motor like a valve or somthine hydrolic. then i would just run the motor for a while and see what happens. I know it's not the best idea but as long as your getting a good spark from the ingnition coils, the plugs are good and the motor is turning fine then you shouldn't be able to hurt anything. Keep in mind you could have an air pocket in your oiling system or you might not be getting pressure to the hydrolic lifters and timing chain tensioner. Id have a mechanic drop by and test your oil pressure when you start it again. Without oil the M42's won't run properly.
any more questions just ask me.. i'm not a mechanic but i've spent a lot of quality time with my motor.
08-25-2003, 07:29 PM
#11
Car: E30 325i 1990
slowered318: i don't think the head gasket has blown but maybe there is something seized as you said. I'm actually reassembling the engine to make it run, hope it will start just as yours did
Did you get to know what was your problem?
nb: the engine has something like 285 000 km, maybe that doesn't help  gotta upgrade to M3 engine!
08-25-2003, 08:35 PM
#12
Well i had to rebuild mine at 150,000 km's becaue the rings and pistons were worn to shit and that damn lucas film crap was gumming up all the oil passages with gunk!
Never found the reason for the hard starts.. but after it was rebuilt it started like a dream.. no smoke, no studder... nothing. It fired up better then ever. hard starts are usually a sign of bad compression and bad ignition.
But if you motor has that many km's on it i would consider replacing it with an M20 or M50
