Old 08-17-2003, 06:37 AM   #1
SickFinga
SickFinga's Avatar
Angry What the hell my fuse is burning out.
Anyway yesterday my fuse #44 burnt out.
I was driving back from the meet, my radio went out.
next day i check my fuse 44 was out.
Replaced it, couple of minutes later it was out again.
This fuse takes care of Radio, Glove box light, windshield wipers and User Operations (WHAT THE HELL IS THE USER OPRATIONS??)
I went to Brian's house got another fuse put it in.
Car was on for about 30min. Radio was working, after about 10minute drive fuse died again.
WHAT THE HELL!!!
I didn't even do anything. Also i got no clue where to start to look for a problem.
Old 08-17-2003, 07:10 AM   #2
Mitch555
Retired MaXmember!
Mitch555's Avatar
Re: What the hell my fuse is burning out.
WHAT THE HELL!!!
Are you sure that you are using the right fuse that is meant for your car? Try a fuse that can handle more load also. What did you guyz do after we left on Friday?
Mitch555 is offline   Reply With Quote
Old 08-17-2003, 07:18 AM   #3
SickFinga
SickFinga's Avatar
yes i'm sure it is the right fuse.
we went home
Old 08-17-2003, 07:23 AM   #4
Mitch555
Retired MaXmember!
Mitch555's Avatar
we went home
I was with you there man!! lol Black E36 with the 19inch BBS CH's. I split the pizza with you and Jon at Pizza Pizza.
Old 08-17-2003, 07:26 AM   #5
SickFinga
SickFinga's Avatar
i know, after i posted it, i checked who asked. And was like WTF YOU WERE THERE Then edited the post
Old 08-17-2003, 07:26 AM   #6
Mitch555
Retired MaXmember!
Mitch555's Avatar
I didn't noticed you just edited... it said you went to woodbridge and I was like... uhhh... I was there with you! lol
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
Old 08-17-2003, 07:28 AM   #7
Mitch555
Retired MaXmember!
Mitch555's Avatar
HAHA... I understand... afterall itz almost 4:30 in the morning! So you guyz just went home after we left?
Old 08-17-2003, 07:32 AM   #8
SickFinga
SickFinga's Avatar
well i drove Kenny and Mike home, then went home. That's when my fuse burnt out. Then I went home, and just felt asleep
Old 08-17-2003, 02:17 PM   #9
You've got a short in the circuitry somewhere, which will SUCK to find. Kinda like my heated seats which eat fuses similiarly, it's a short or other wiring problem somewhere in the mess.
Old 08-17-2003, 10:16 PM   #10
KennyTheGreat
KennyTheGreat's Avatar
Send a message via ICQ to KennyTheGreat
maybe it's drift related
cuz after u did those drifts last night, ur radio stopped working again....hrmm??
j/p
KennyTheGreat is offline   Reply With Quote
Old 08-18-2003, 05:09 AM   #11
nzer
nzer's Avatar
yeah there is an earth fault somewhere which is being caused by one of the things.. most likely a switch..
good luck finding it
BMWs Downunder
http://www.bimmersport.co.nz
nzer is offline   Reply With Quote
Old 08-18-2003, 05:22 AM   #12
Gamite
Gamite's Avatar
I only got one thing to say:
"I DIDN'T DO IT!!"
......for once..
www.gamite.net
Old 08-18-2003, 06:23 AM   #13
KennyTheGreat
"I DIDN'T DO IT!!"
......for once..
hahahahaha
tho you did see him a few days prior to this...
Old 08-18-2003, 06:27 AM   #14
Gamite
Gamite's Avatar
maybe cuz I touched it on friday morning..
www.gamite.net
Old 08-18-2003, 12:41 PM   #15
sonic07
sonic07's Avatar
have you done the short circuit testing with the ohm meter ? or with volt meter ?
make sure disconnect harness connector from circuit load
with the fuse off and power off use the ohm meter one lead to fuse and one lead to ground if there is continuity ... there is a short.
using volt meter with car power on, connect one lead to fuse terminal and the other lead to the other side fuse terminal if you see voltage that means there is a short.
i would imagine it's a pain to troubleshoot it back ward.
radio uses fuse 44 and fuse 9 as well
glove compartment, ashtray, charging socket, lighter
uses fuse 44, 32, 33, 37
perhaps i suspect a lose wire/connector somewhere that cost the overload may be behind the stereo console or behind the glove compartment .....
good luck.
Pedal To The Metal
sonic07 is offline   Reply With Quote
