Old 08-12-2003, 09:50 PM   #1
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
Send a message via ICQ to HooliGaN* Send a message via MSN to HooliGaN*
e36 corners
i wanna install my clear corners which are on the way
how do i start the procedure?
what do i have 2 remove inorder to do this?
what tools do i need?
help me out here with any advice
thanx
Julian
HooliGaN* is offline   Reply With Quote
Old 08-13-2003, 01:35 AM   #2
madddskillz
it's pretty easy
i think the instructions are in the manual.
madddskillz is offline   Reply With Quote
Old 08-13-2003, 01:51 AM   #3
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
ill check it out if not id appreciate any help
Old 08-13-2003, 05:30 AM   #4
Mitch555
Retired MaXmember!
Mitch555's Avatar
Re: e36 corners
thanx
Julian
They just snap on to the side of the headlight so they don't fall off. Unclip it and slide it out towards the front of the car. Then your done. Hopefully this helps!
P.S. make sure you remove the turning signal bulb b4 you remove it!
Mitch555 is offline   Reply With Quote
Old 08-13-2003, 03:20 PM   #5
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
ok ill try this so your saying i need no tools or anything?
Thanx
Julian
Old 08-13-2003, 07:03 PM   #6
Mitch555
Retired MaXmember!
Mitch555's Avatar
Thanx
Julian
No tools bro!
Old 08-13-2003, 07:22 PM   #7
marco328is
marco328is's Avatar
No tools needed................but if it gets kind of rough use a screw driver
marco328is is offline   Reply With Quote
