Old 08-11-2003, 02:28 PM   #1
Rod
Doriftoooo!
Rod's Avatar
Unhappy Blown Engine?
Sad overrev story
Last thursday night, I misshifted and instead of going to 5th, i nailed 3rd for like 5 sec, and then *BOOM*, the loudest noise I've heard coming out of a car!
As soon as i pressed the clutch back in the car started backfiring, and it went dead. Check engine light came on, as well as the oil and every other light on the dash.
Had to push the car for like forty five minutes to get it home.
I don't know yet what i broke or bent.
You guys have any suggestions over which mechanic i should go see? I need a good mechanic that can work well on Euros. We might be talking engine swap. I live in the Ottawa area.
Rod
Check out some of my own E90-inspired clothing: Click here!
Rod is offline   Reply With Quote
Old 08-11-2003, 02:33 PM   #2
BMW_7
Econobimmer Racing
BMW_7's Avatar
That happened to me once or twice but thankfully I shifted at the 3,000 rpm range.
Vitaliy
Old 08-11-2003, 02:43 PM   #3
Rolled_Out
Just chillin...
Rolled_Out's Avatar
whoa.. what a co-incidence..
dealer just called me and said.. "were taking your car in, in an hour, if you mis-shifted and blew the motor, its not covered under warranty" i told them i didn't mis shift...
now i read THIS 2 seconds later.... uh oh!!!
i didn't mis shift when my engine died, but i did however over a week ago, the first time in at least 6 months..but the car has been driving fine since then, so i dont know..!
"**** the haters...we have no competition"
Rolled_Out is offline   Reply With Quote
Old 08-11-2003, 03:04 PM   #4
Rod
Doriftoooo!
Rod's Avatar
I'm thinking of bent valves, or possibly new head and pistons... Don't know yet.
I need to find a good place to bring it first.
Old 08-11-2003, 03:25 PM   #5
WASABI
OG
I hope it's not as bad as is sounds. Check out some pics from this thread, this would probably be the worst case scenario.
http://www.maxbimmer.com/forums/show...ighlight=broke
Old 08-11-2003, 03:51 PM   #6
Rolled_Out
Just chillin...
Rolled_Out's Avatar
this is what happened, i leave my house, i didn't drive it hard @ all, about 2 mins later, i shift from 1nst to 2nd @ about 6,000 rpm, and i THOUGHT i heard something spinning around (my music was on, i turned it down and then heard nothing) then my car died, i look back, see a small puff of white smoke from the exhaust, and roll in to the next street, the car won't start...
it ALMOST starts but it has problems and cant keep the idle...
timing belt i HOPE but the cars only got like 18,000 km on it!
is it possible for that to happen w/ 18k on it?
Old 08-11-2003, 04:37 PM   #7
97 Z3 2.8
I've seen a couple of mis shift deaths before. One had nice little amuminium chunks in the oil pan....time for a swap, the other had a valve float right into a piston....yet again swap and the third got luck and just spun the engine too fast, skoring the cam. That one only needed a top end rebuild.
White smoke= Coolant burning. Could be valve, head gasket. Sounds as though it may be your head gasket.
Bill
Bill
1997 Z3 with N/A power adders....
97 Z3 2.8 is offline   Reply With Quote
Old 08-11-2003, 04:48 PM   #8
Rolled_Out
Just chillin...
Rolled_Out's Avatar
just talked to them..
they said there was an extreme amount of oil coming up through the throttle body, and i need a new longblock, (basically a whole new motor)..
Old 08-11-2003, 05:04 PM   #9
Jattdee328
Jattdee328's Avatar
RSX's aer know to have blown motors, my friend is a tehc at an Acura Dealership
he says he does one once a week.
Harps
HaVaaa vich kadey nee chiraag jug de...Juch de PUNJABI nahiyoon binna PUG de
Jattdee328 is offline   Reply With Quote
Old 08-11-2003, 05:05 PM   #10
Rod
Doriftoooo!
Rod's Avatar
I feel your pain man.
I still dont know whats wrong with mine.
Its getting towed to my mechanic tomorrow morning.
Old 08-11-2003, 05:05 PM   #11
Rolled_Out
Just chillin...
Rolled_Out's Avatar
can you ask him to call me please??
check your PM for my cell #...
Old 08-11-2003, 05:33 PM   #12
Jon@Bimmersport
Jon@Bimmersport's Avatar
danny ITR MOTOR!!!!!!!!!!
Old 08-11-2003, 05:36 PM   #13
tlaselva
1800+ HP Driveway
tlaselva's Avatar
Harps
There's an increased case of blown engines with the RSX's cuz they're being driven hard. Drive any car hard consistantly, especially a lower displacement engine, and you can kiss the reliabilty goodbye .... doesn't matter that it's v-tec this or that..........
E46 Engine's were also had a marked increase of engine failures.
Same issue. Car's being raced frequently=engine failures.
2011 X5 M-Sport 3.5i
2010 Dodge Ram Hemi Sport
2010 GSX-R 750
2003 C5 Z06
903rwhp/815rwtq : 10.3@152mph
Old 08-11-2003, 07:28 PM   #14
Peter1998
i downshift from 4 to 3.. at 6500rpm.. it go to like 7500rpm-8000rpm... no problem to my car.. i trid it so many time on track..
Peter1998 is offline   Reply With Quote
Old 08-11-2003, 08:57 PM   #15
Alezone
Capitalism
you're risking it... I wouldn't downshift when I'm already at 6500, should shift up to get more power (if that's your purpose, or you brake and downshift/heel-toe to go into a corner...), good luck.
Current:
2014 Jeep Wrangler Unlimited
2002 996 C4S
Alezone is offline   Reply With Quote
