Old 03-30-2002, 12:42 AM   #1
SickFinga
SickFinga's Avatar
Highbeam Relay.
Anyone know where is highbeam reley located in '97 M3/4?
I have a service manual book and it says it should be in power distibution box, I opened it, and it's not there the highbeam relay's spot is empty all other relays are there.
Also in the book I found out that it could be located behind instrument cluster, but in a book it says 1998 models only, my car is late 96.
in cars from 92-97 it's should be in power distibution box, but like I said it is not there.
I tried to unscrew speedo, but it has some special bolts.
So anyone know where is it? I don't wanna try to unscrew my speedo and find nothing there.
Also if it's behind instrument cluster anyone got any idea how can I unscrew those special bolts?
Old 03-30-2002, 02:03 AM   #2
M52_Alpina
no no no, you don't have to unscrew the speedo.. the relay is located under the dash, just above and to the and to the left of the steering column.. remove the big plastic panel under the dash (the panel which is right above your knee when you sat in the driver seat).. look for a big blue relay (assuming your car has day time running light) and this is the highbeam relay... hope that helps.
///M FREE
M52_Alpina is offline   Reply With Quote
Old 03-30-2002, 03:22 AM   #3
SickFinga
SickFinga's Avatar
just remove that panel at 2:10am and I found nothing except ODB connector
Old 03-31-2002, 02:05 AM   #4
SickFinga
SickFinga's Avatar
ok because it was 2:20am I found nothing, today in the mornig I found that relay.
Thanks M52_Alpina, if not you I would still looking for that relay behing cluster panel
Old 04-01-2002, 07:33 PM   #5
M52_Alpina
you're welcome
///M FREE
