Old 08-08-2003, 02:05 PM   #1
Autotechnica
BMW Traitor
What's the largest size rotor that will fit in a 15" rim?
I have 17" M3 wheels for the summer, but in the winter I use 15" OEM alloys so I need a set of rotors that will fit 15" unfortunately. I've been offered a set of 13.5" rotors from Brembo for a great deal. Any idea if these will fit without problems?
Thanks,
Bryan
'02 Mercedes C32 AMG 3.2L Supercharged @ 18psi - 341WHP/358lbs*ft TRQ (DynaPak) Eurocharged custom tune, ASP 178mm crank pulley + PSK, CM30 i/c pump, i/c iso kit, Magnecore wires, NW CAI, dual custom exhaust, H&R sway bars, H&R SS coilovers, KMAC camber kit, H&R spacers, Quaife ATB LSD, goodridge SS lines, Porterfield RS4 pads, AMG 18" rims, AEM UEGO wideband, Dashdaq datalogger, Kenwood Excelon DNX8120
Old 08-08-2003, 03:33 PM   #2
moregothanshow
All Show No Go!
moregothanshow's Avatar
doesnt the offset also determine if the brakes/rotors will fit? as for a 13.5 inch rotor fitting in a 15" wheel i doubt it.... correct me if im wrong but dont you also need calipers or maybe brackets in order to fit these rotors? or is it a whole brake system upgrade u will be doing??
either way, i know for a fact the Stock M3 rotors/brakes/caliper which is i think 12.4 up front and 12.3 in the rears will not fit in anything smaller than a 17" wheel so i am pretty sure u will need to either get another set of 17" or maybe some 17" steelies for the winter.......oh and they do exist.....hehehehe
Old 08-08-2003, 03:34 PM   #3
moregothanshow
All Show No Go!
oh yeah are you going to be going all around or just the front brakes? if it is just the front brakes maybe get 2 crapy 17" wheels and just use them up front....it'll probably look funnie 15's in the rears and 17's up front
Old 08-08-2003, 04:18 PM   #4
KIRASIR
Your Nightmare
KIRASIR's Avatar
Re: What's the largest size rotor that will fit in a 15" rim?
You will need calipers and carriers, and possibly new kingpins depending on the model of the brakes. And no, they will not fit 15" wheels, since the calipers won't clear the wheels.
I actually just ordered some brakes 2 days ago. In a couple of weeks I'll have 325mm rotors on the front.
SL
Thanks,
Bryan
Old 08-08-2003, 07:38 PM   #5
moregothanshow
All Show No Go!
what kind of brakes??
Old 08-08-2003, 07:46 PM   #6
KIRASIR
Your Nightmare
KIRASIR's Avatar
330 e46
SL
Old 08-08-2003, 08:05 PM   #7
paul
how much is it going to cost you and do ypu have the part numbers needed.
i know that this topic has been taked about. someone has pasted info from the website and dtm website regarding what fits and what is need. this info would be of great help to me guys thanx
paul is offline   Reply With Quote
Old 08-09-2003, 01:44 AM   #8
Peter1998
minimum for 330 break is 17 inch wheels
Peter1998 is offline   Reply With Quote
Old 08-09-2003, 01:44 AM   #9
Peter1998
for 15inch wheel. u need 11.5 inch disc
Old 08-09-2003, 02:02 AM   #10
moregothanshow
All Show No Go!
so who has the better brakes?? E36 M3 or the E46 330??
Thanks!
Old 08-09-2003, 02:14 AM   #11
KIRASIR
Your Nightmare
KIRASIR's Avatar
It's about the same with e46 being MUCH cheaper to get.
e46 330 - 325x25mm rotors
e36 M3 - 315x28mm rotors
M3 ones are slightly thicker but less in diameter.
Now compare that to what I have now: 285x12mm
SL
Thanks!
Old 08-09-2003, 03:47 AM   #12
Autotechnica
BMW Traitor
It was sold as a kit, came with 4 piston calipers, SS brake lines and 13.5" brembo cross drilled rotors. All for only $400! Well, since I can't use them, anyone else want to buy them?
What are stock size rotors on a 318?
Bry
Old 08-09-2003, 04:22 AM   #13
KIRASIR
Your Nightmare
KIRASIR's Avatar
see above. 285x12mm . It's a foking disgrace to a BMW.
SL
Bry
Old 08-11-2003, 06:39 PM   #14
moregothanshow
All Show No Go!
what kind of caliper is it? is it a straight bolt on to a 318? or do you need the M3 spindles?
Thanks!
Old 08-13-2003, 05:37 AM   #15
Mitch555
Retired MaXmember!
Mitch555's Avatar
I heard 11" is the biggest rotor you can put in with a 15" rim.
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
Mitch555 is offline   Reply With Quote
