Old 08-06-2003, 03:36 PM   #1
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
Send a message via ICQ to HooliGaN* Send a message via MSN to HooliGaN*
Cluster Service computer
how do i reset the service computer like for oil changes etc?
cause im not gonna bring it to bmw dealer if i can do it myself and i dont want the thing to always be on service?
i know its possible on my parents mb
is it possible on the bmw?
it hasnt got the point where the lights are red or anything but id like to know for future refrence?
HooliGaN* is offline   Reply With Quote
Old 08-06-2003, 03:47 PM   #2
Bad Man
IT'S POSSIBLE!
Very simple! All you basically do is like hold two pins for a few secs on that computer thing.......Its been a while since I last did it, I saved some picture on my gfs comp, so once I get on it...I'll post it, ite?
eZ bro
Representin' B'Town
Bad Man is offline   Reply With Quote
Old 08-06-2003, 05:40 PM   #3
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
thanx bro
i really appreciate it
by two pins do u mean the ones on the cluster panel
because if so i only have 1 pin
Julian
Old 08-07-2003, 02:09 AM   #4
Bad Man
Take a look bud
Representin' B'Town
Old 08-07-2003, 02:10 AM   #5
Bad Man
The service indicator lights are reset by connecting pin 7 to pin 19(ground). The proper way to do this is to have the ignition off and place a jumper wire between pins 7 and 19 (make sure you get the right pins!). Then turn the ignition switch to position 2 (run, NOT start), when the service light goes out, turn the ignition off. This should take a few seconds for an oil reset, 8-10 seconds for an inspection reset. All green lights should come on when the service light goes out. The difference between resetting the oil service light and the inspection light is in the length of time you have the jumper in place with the ignition on. This means that if you are resetting the oil service light, you should turn off the ignition immediately after the light goes out. If you leave the jumper in too long with the ignition on, you will perform an inspection reset as well and the next service indicator will come up as an oil service rather than an inspection.
I found this helpful from some site a while back...Good luck!
Representin' B'Town
Old 08-07-2003, 02:46 AM   #6
HooliGaN*
GILF HUNTER
HooliGaN*'s Avatar
thx dude ill try it out
i owe you man
hope i dont short anything
Julian
