Old 08-04-2003, 03:04 PM   #1
blkm3
E36 radio installation??
I was trying to change my stock radio to an aftermarket one . Does anyone know what each color on the BMW wire harness represent ex what color is the ( power , left speaker etc...) Also I had a friend who tried to connect the radio but there is no sound from it but the radio works perfect . Does anyonw know if it has to do with the stock amps, if so how does any buy pass this . Any help would be great
blkm3 is offline   Reply With Quote
Old 08-04-2003, 10:07 PM   #2
blkm3
doesnt anyone know ??? no one change their radio???
Old 08-05-2003, 02:46 AM   #3
sonic07
sonic07's Avatar
i don't have the colour code for the radio but i have this pin # what they're for ..... i hope this will help you ....
Pedal To The Metal
sonic07 is offline   Reply With Quote
Old 08-05-2003, 04:33 AM   #4
Alwysfresh
Registered User
Alwysfresh's Avatar
vio/wht - hot in accy, run and start
red/wht - hot at all times
yel - cd changer
yel/red & yel/brn - left front speakers (low and high)
yel/vio & yel/gry - left rear speaker
blu/blk & blu/brn - right front speakers (low and high)
blu/vio & blu/gry - right rear speaker
gry/red - interior lights system
brn - ground
blk/wht - instrument cluster
wht/brn - telephone connector
wht - antenna amplifier
Hope this helps
Alwysfresh is offline   Reply With Quote
Old 08-05-2003, 11:35 AM   #5
blkm3
thanks guys that helps a lot . Does anyone know if I have to bypass the original amps??? or do I just hook hup the radio and it will work?
Old 08-05-2003, 03:14 PM   #6
Jesse
People have told me in the past that if you don't bypass the original amplifier your system will sound like crap, but I never did it (too much work) and mine sounds fine.
I have a Kenwood 400W amp with one 10..., which is more than enough. I replaced all my stock speakers with pioneer 140w and they haven't blown yet (1 1/2 yrs).
Jesse is offline   Reply With Quote
Old 08-05-2003, 04:32 PM   #7
95 325i
You can get an adapter for most systems so that you don't have to cut the origional connector. Their only like $15.00 to $25.00.
95 325i
95 325i is offline   Reply With Quote
Old 08-06-2003, 12:14 AM   #8
Predator_e36
AKA:e36=m3square
Predator_e36's Avatar
Send a message via ICQ to Predator_e36
first u need a wirin harness and a radio adapter. and the reason why ur not gettin any sound is because ur oem amp is not on, u need to hock up the blue wire
Predator_e36 is offline   Reply With Quote
Old 08-06-2003, 12:18 AM   #9
marco328is
marco328is's Avatar
Thumbs up
go buy the harness adapter @ Canadian Tire
It's $20
marco328is is offline   Reply With Quote
Old 08-06-2003, 03:17 AM   #10
blkm3
Canadian tires ???? I dont think they stock bmw parts. but thanks for the advice anyways . does anyone know where this adapter cheap . Also the blue wire was hooked up and still the amps did not turn on . Do I hook it up to the acc power???
