Old 07-29-2003, 09:11 PM   #1
328power
GAS GUZZLER !!
328power's Avatar
Crank Sensor / Cam Sensor
AAAA how sweet it is,,,
I finnaly made myself bring my car in after i have a cold start problem for the last 6 months ( takes 3-5 tries after sitting for more than 6 hours )
Brought it in to Chucks auto and after a couple hit and misses.... They changed the Crank and Cam sensors and they say its fixed but i am leavin it there one more night to see if it did in the morning...
Has anyone had to change either before ??
ex bimmer man/ex subaru man turned Dual V8's Jeep&Vette
328power is offline   Reply With Quote
Old 07-30-2003, 12:12 PM   #2
328power
GAS GUZZLER !!
328power's Avatar
nope its not fixed ...they thought it worked but it didnt....unbelievable...
The problem that no one can fix...
Old 07-30-2003, 10:05 PM   #3
notjoe
600rwhp here i come
notjoe's Avatar
Send a message via ICQ to notjoe
Maybe air is getting into the gas line if the car sits for a while/doesnt have any pressure on the line and it takes the injectors/fuel pump a couple of trys to bring the fuel back up?
notjoe is offline   Reply With Quote
Old 07-31-2003, 02:53 AM   #4
BlackTape
Last month my I had the same problem... My car wouldn't start... It would crank but never fire.... Like an idiot I though it was the battery and I tried jump starting my car and I even used Spray starter to try to start the danm thing...
My car was sittin in the garage when it would start so I had to get it towed.
The shop I took it too charged me like 700 dollars for diagnostics and then finnaly the relacement of the crank sensor.
BlackTape is offline   Reply With Quote
Old 07-31-2003, 12:46 PM   #5
328power
GAS GUZZLER !!
328power's Avatar
mee tooo...over 700 so far
Old 08-10-2003, 06:01 AM   #6
Peter1998
so. what did u changed recently? only crank sensor and cam sensor? did u check all those basic things? spark plugs and else? all great? if u hit some gas while start it.. will it be easier? for hard to start.. there is so many things to try...
Peter1998 is offline   Reply With Quote
Old 08-10-2003, 09:38 AM   #7
SickFinga
SickFinga's Avatar
if i'm correct crankshaft sensor was a recall on e36 and any BMW dealeships should change it for free.
On my strut tower i have a bmw sticker that says that my sensor was changed due to recall.
Old 08-10-2003, 04:21 PM   #8
328power
GAS GUZZLER !!
328power's Avatar
I have changed the water pump , fuel pump , head gasket, crankshaft and camshaft sensors, 3 way valve.....i have checked the spark plugs their fine ...and pressing the gas while start doesnt help : (
Old 08-10-2003, 04:28 PM   #9
Peter1998
it left out.. Starter or DME or fuel regulator to check i think...
Old 08-10-2003, 09:04 PM   #10
328power
GAS GUZZLER !!
328power's Avatar
yeah fuel reg ,may be it
