Old 07-31-2003, 03:58 PM   #16
KIRASIR
Your Nightmare
KIRASIR's Avatar
http://www.koalamotorsport.com/tech/...balljoints.htm
I have personally taken both of my controls arms out, and there is no way INNER ball joints can be replaced.
1) they are not available from the dealership
2) they are part of the control arm, and cannot be removed.
SL
Originally posted by Furious325is
to clarify the whole balljoint issue, ive been told that the inners dont go as easy as the outters do, and they can just replace the inner balljoint without having to replace the whole control arm. if you have to replace the whole thing its because its recomended (or maybe its a way to get more money) ive personally seen the inners replaced on both an e30 and e36.
Old 07-31-2003, 04:50 PM   #17
Autotechnica
BMW Traitor
Still confused..
'02 Mercedes C32 AMG 3.2L Supercharged @ 18psi - 341WHP/358lbs*ft TRQ (DynaPak) Eurocharged custom tune, ASP 178mm crank pulley + PSK, CM30 i/c pump, i/c iso kit, Magnecore wires, NW CAI, dual custom exhaust, H&R sway bars, H&R SS coilovers, KMAC camber kit, H&R spacers, Quaife ATB LSD, goodridge SS lines, Porterfield RS4 pads, AMG 18" rims, AEM UEGO wideband, Dashdaq datalogger, Kenwood Excelon DNX8120
Old 07-31-2003, 04:53 PM   #18
KIRASIR
Your Nightmare
KIRASIR's Avatar
Which part you don't understand?
From the link posted above:
]There are two ball joints on each control arm of a 3 series car.
If you have a bad ball joint on an E30 you will need to replace the control arm as a
complete unit, this does not come with a new rear bushing or bracket, so now is the time
to change your bushings also.
E36 vehicles do not require replacement of the control arm if the outer ball joint is bad,
if the inner one is bad, you must replace the complete control arm, again, the rear
bushing and bracket are separate.
[quote]Originally posted by Autotechnica
Still confused.. [/QUOTE
Old 07-31-2003, 05:01 PM   #19
Autotechnica
BMW Traitor
[quote]Originally posted by KIRASIR
Gotcha, perhaps some people are confusing the inner control arm bushing with the inner control arm balljoint. Control arms are a pain in the ass. If you have the money and don't want to bother replacing things seperate, just buy the whole control arm. Or better yet, a LTW Aluminum control arm
Bry
Old 08-01-2003, 01:11 AM   #20
Furious
BMW again.
Furious's Avatar
my fault i was thinking outside , yes ya have to replace the whole arm. i had to get under to check myself, thanks for the correction KIRASIR
Old 08-02-2003, 12:40 AM   #21
bimmersport
bimmersport's Avatar
SL
You are correct in saying that they are NOT available from the dealer BUT wrong in saying that they are not removable. You can buy the inner ball joints seperately aftermarket(around $30each). I have replaced them many times (without replacing the complete arm), and most recently on the control arms for notjoe's car.
BIMMERSPORTAUTOMOTIVE
Specializing in BMW parts and service
905-670-9200
www.bimmersport.ca
bimmersport is offline   Reply With Quote
Old 08-02-2003, 01:04 AM   #22
Autotechnica
BMW Traitor
Awesome! Thanks Charlie
Bry
Old 08-02-2003, 01:10 AM   #23
notjoe
600rwhp here i come
notjoe's Avatar
Send a message via ICQ to notjoe
This i can vouch for! I watched him torch it off and put on the new one myself. I too was sure that they could not be replaced since it was exactly that which everyone was telling me, until i saw it.
notjoe is offline   Reply With Quote
Old 08-02-2003, 04:02 PM   #24
KIRASIR
Your Nightmare
KIRASIR's Avatar
Hey Charlie,
You should visit this board more often. We need this kind of inside information once in a while.
OKay, I stand corrected.
However, when I replaced mine, I actually went to a parts supplier and they had no ball joints at all for e36 in their database (This was a pretty big wholesale parts distributor.). So I ended up buying a set of outer ones from the dealer.
Could you be more specific about the actual procedure?
How are they removed and what tools are required? Also how are the new ones installed?
When I installed mine I read every single peice of info on the net about replacing balljoints, and this is the first time I hear about inners being replaced.
I might as well replace them now on my car.
SL
PS One a side now, Charlie, how much do you charge for clutch replacement?
